intake gasket
Old May 24th, 2015, 08:03 PM
fatback's Avatar
intake gasket
I orderd a intake gasket for the 55 from rock auto. they sent me a metal gasket by felpro. is this the gasket I want to use? never seen a metal gasket for intake before. if so what kind of sealer should I use?
fatback is offline
Old May 24th, 2015, 09:12 PM
Ozzie's Avatar
Post
The original gasket was a graphite coated metal gasket (group 3.270; part 564040) which required no sealer. Oldsmobile uses metal gaskets on the intakes a lot. On the non-original gaskets I've used a very thin sealer. Be sure that the surfaces are clean. Check to see if the gasket manufacturer has a recommendation on the sealer. The Oldsmobile shop manual recommends to dip the threads of the manifold bolts in C.P.#9 sealer and torque to 22-26 ft.-lbs. according to the designated sequence shown in the manual.
Ozzie is offline
Bobac455
December 4th, 2013 09:23 AM
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: intake gasket
