First generation olds engine in buick 1956
Old Apr 9, 2022 | 01:45 PM
Love1955oldsmobile's Avatar
Is there anyone here with experience in putting first generation oldsmobile engine ( including 1953 with dynaflow) into 1954 to 1956 buick (big or little series).
Yes I know about with money anything is possible.
Ron
Old Apr 9, 2022 | 03:19 PM
Why? I mean, I'm all over Olds power, but in a '50s Buick? I'm sorry, but I just don't get the point.
Old Apr 9, 2022 | 04:46 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Why ??? The 322 nail head Buick was a great engine. Maybe not as good as the first gen Olds but a very good engine.
Old Apr 9, 2022 | 05:29 PM
rocketraider's Avatar
Oldsdruid
Even with a 1953 Olds Dynaflow you still have to mate it to the Buick's torque tube and figure out a way to start it. Buick was using Carter carbs back then and DK how you'd adapt Buick's gas pedal start to an Oldsmobile's Rochester.
Use the Nailhead and a Buick Dynaslush. Makes things a lot simpler.
Old Apr 9, 2022 | 05:38 PM
Charlie Jones's Avatar
Phantom Phixer
While Olds did install a number of Dynaflow transmissions in late 1953, they were different from the Buick version,
The flywheel housing on the front was different, to bolt up to the Olds motor.
The flywheel was different, even the crankshaft was different in the engine.
Besides that, the output shaft and rear tail housing are different.
Because Olds used an open driveshaft, where Buick used a closed "torque tube " driveline.
I suppose someone could build a " franken-tranny " with an Olds and a Buick trans.
That would fit both the Olds motor and the Buick driveline, but WHY ??
Old Apr 11, 2022 | 08:49 PM
Why your asking?
I am pondering making an 1955 oldsmobile station wagon.
So a buick drive line is out of the question.
I have lots of 1955 olds parts. Why not have something different?
Ron
edshbennett
Nov 23, 2019 06:58 AM
James Burke
Jul 10, 2018 03:18 PM
congers
Dec 2, 2016 10:58 AM
kaptmikey
Nov 27, 2012 10:49 AM
starman63
Sep 16, 2012 08:43 AM
