Throttle linkage rod to tunnel ram?
I know this is a dumb question, but does anyone know how to adapt the throttle rod linkage to angle up to a tunnel ram? I'm ok with going with a cable as I'm buying (pic)
but I don't want to replace the pedal assembly.
Stupid question time: how you gonna be OK switching the part you see readily versus not wanting to switch the part that's hard to see?
Those brackets are universal junk- don't pay more than $15-20 for it. They're all basically the same, and Summit charges $60. Make sure it will clear anything that will be close (my air cleaner base wouldn't work). I have a black one I'll send you if you want it.
I just put the Lokar pedal in. I really can't say enough good things about it. It's expensive, but worth it in weight savings alone.
That bracket goes to 2 studs/bolts, provides a return spring(s), and secures the cable sheath (not provided). You can use bicycle cable as a cheap alternative, but you need a pedal for a cable. My 67 had linkage, and I couldn't figure out an acceptable (to me) way to make it pull a cable. That's why I gutted the factory, and installed the Lokar.
https://www.speedwaymotors.com/Lokar...BoCDsoQAvD_BwE
It's a direct bolt in, but the cable doesn't come with.
What about this, might work with your stock pedal and linkage
https://www.amazon.com/Aluminum-Bell...75NLR7VH&psc=1
1965cutlassragtop
March 18th, 2017 06:59 AM
