Throttle linkage rod to tunnel ram?
Old Dec 9, 2021 | 06:56 AM
Coastie's Avatar
Stock cars are too boring
I know this is a dumb question, but does anyone know how to adapt the throttle rod linkage to angle up to a tunnel ram? I'm ok with going with a cable as I'm buying (pic)
but I don't want to replace the pedal assembly.
Old Dec 9, 2021 | 07:10 AM
fleming442's Avatar
Stupid question time: how you gonna be OK switching the part you see readily versus not wanting to switch the part that's hard to see?
Those brackets are universal junk- don't pay more than $15-20 for it. They're all basically the same, and Summit charges $60. Make sure it will clear anything that will be close (my air cleaner base wouldn't work). I have a black one I'll send you if you want it.
I just put the Lokar pedal in. I really can't say enough good things about it. It's expensive, but worth it in weight savings alone.
Old Dec 9, 2021 | 07:20 AM
Coastie's Avatar
from my understanding, that bracket hooks up to the carb and you just need to connect the rear to the throttle linkage for it to work? I guess I'm just looking for the cheapest and easiest method to do this since the budget is getting tight, and I want to have it all done before February. I'm not opposed to using a coat hanger and bending it if that's what I need to do lol
Old Dec 9, 2021 | 08:02 AM
fleming442's Avatar
That bracket goes to 2 studs/bolts, provides a return spring(s), and secures the cable sheath (not provided). You can use bicycle cable as a cheap alternative, but you need a pedal for a cable. My 67 had linkage, and I couldn't figure out an acceptable (to me) way to make it pull a cable. That's why I gutted the factory, and installed the Lokar.
Old Dec 9, 2021 | 08:27 AM
Coastie's Avatar
Do you have a link for the exact one you got? And did you have to do any modifications to make it work or was it a direct bolt in?
Old Dec 9, 2021 | 09:11 AM
fleming442's Avatar
https://www.speedwaymotors.com/Lokar...BoCDsoQAvD_BwE
It's a direct bolt in, but the cable doesn't come with.
Old Dec 9, 2021 | 09:50 AM
Coastie's Avatar
God damn.
Old Dec 9, 2021 | 09:59 AM
70W-32's Avatar
Originally Posted by Coastie
God damn.
Was that a "God Damn" thats nice
or "God Damn" thats expensive?
Just a side question, do you know any of the ( "Coasties") that tried to rescue the lady at Niagara on Wednesday
Old Dec 9, 2021 | 10:08 AM
fleming442's Avatar
I said it was expensive!!!
Old Dec 9, 2021 | 10:17 AM
70W-32's Avatar
What about this, might work with your stock pedal and linkage
Amazon Amazon
Old Dec 9, 2021 | 10:35 AM
Coastie's Avatar
expensive and that they can't throw in a cable for that price lol. No I do not, it's a small CG, but not that small.
Old Dec 9, 2021 | 10:36 AM
Coastie's Avatar
https://www.amazon.com/Aluminum-Bell...75NLR7VH&psc=1
that's interesting. I'm trying to figure out how it works in my mind
Old Dec 9, 2021 | 12:24 PM
70W-32's Avatar
Maybe this will help. Lower right is for the throttle from your pedal
Upper left attaches to the carb
Old Dec 9, 2021 | 12:31 PM
70W-32's Avatar
This is CG Rescue from Selfridge ANG. They flew from Michigan to Niagara, NY, to attempt this rescue before the car went over the American Falls.
1965cutlassragtop
Mar 18, 2017 06:59 AM
pizzyp
Nov 3, 2014 11:23 AM
miked
Oct 26, 2013 07:09 PM
TripDeuces
Jun 28, 2010 09:34 AM
66starfire
Apr 29, 2007 08:46 PM
