1961 olds super 88 questions 394
Old March 8th, 2014, 09:50 AM
oldrelics's Avatar
1961 olds super 88 questions 394 - more ? on timing
I have a few questions:
1- where is the ign coil resistor supposed to be mounted?
2-checking ATF, run warm and check running?
3-converting to gm alt, will 62 up bracketry work?
oldrelics is offline
Old March 8th, 2014, 10:05 AM
It is not a resister, it is a resistor wire.
Yes, and yes.
You may have to modify the mounting a bit to get the pulley to line up.
oldcutlass is offline
Old March 8th, 2014, 10:36 AM
oldrelics's Avatar
Where does the resistor wire run from?
I'm going to convert to electronic distributor and the kit says to eliminate the resistance.
Old March 8th, 2014, 10:39 AM
I'm not sure on yours. What you can do is use the resister wire to activate a 30a relay to supply a full 12v to your new setup. Or you can just cap the old wire and run a new switched 12v source.
Old March 8th, 2014, 01:19 PM
oldrelics's Avatar
So another question,
to time this 394 I see the two tabs and the mark on the balancer, the spec is 5 degrees, where is that on the two tabs?
Old March 8th, 2014, 02:02 PM
2 tabs or indentations? The line on the harmonic balance should line up with the second indentation on the tab. First is 0, second is 5, third is 10 deg BTDC.
Old March 8th, 2014, 02:37 PM
Early sixties cars had a separate ballast resistor, I believe. It would be a ceramic thing on the firewall. I'm sure a '61 owner can chime in on this.
MDchanic is offline
Old March 8th, 2014, 04:47 PM
justinj's Avatar
Should be a resistor wire if everything's stock. I installed a ceramic one when I re-wired my '62 though.
justinj is offline
Old March 8th, 2014, 04:49 PM
justinj's Avatar
If you don't have a factory service manual, join WildAboutCars.com (free) - you can download PDF's of the 61 manual on that site. It has this type of info, plus a wiring diagram.
justinj is offline
Old March 8th, 2014, 05:21 PM
SavedbyHim's Avatar
I have a stock 61 super 88, resistor is mounted on the intake manifold, no resistor wire.
SavedbyHim is offline
Old March 8th, 2014, 09:34 PM
oldrelics's Avatar
Thanks guys, I found no resistor on the intake and the coil wiring looks factory taped.
I tried to set dwell tonite but it kept sparking out the little window and shorting out when I stuck the little allen wrench in. It would just completely die out when I try and bring it to 30 from 25....
Old March 9th, 2014, 07:38 AM
Hmmmm... That shouldn't happen.
Are you touching the Allen key against anything other than the screw head?
Ideally, you want to use one of those ball-headed Allen keys, or use a purpose-made GM points adjuster, so as not to place a lateral load on the adjusting screw, which will change the setting while you're setting it, so that it snaps back to a different setting when you remove the Allen key.
What sort of dwell meter are you using, and how are you connecting it?
Also, note that changing your dwell will change your timing (which is why you adjust your timing afterward), so that if your dwell is way off, setting it right may change your timing enough that the car won't run. Set your dwell part way, then readjust your timing, then re-set your dwell, then adjust your timing properly.
MDchanic is offline
Old March 9th, 2014, 07:11 PM
oldrelics's Avatar
Okay, I filed the points which then I could set the dwell and timing, I think a carb kit is next and some vacuum issues maybe.
The wire going to the coil is a type of cloth covered wire, resistor? I haven't found a ceramic block anywhere.
Is this a factory power brake booster/master cyl?
This vacuum mess at the back of the carb, factory?
How is the column removed from the steering box?
Old March 9th, 2014, 07:59 PM
I filed the points
Ummmmmm... That hasn't really been considered to be a good idea since about 1951.
When you file them, you can alter the angle slightly, causing burning.
Also, modern points have a thin metallic plating that greatly extends life, and when you file them, it's gone.
Also, since filing removes the "mountain" on one point, but does not remove the "valley" on the other side, it can completely screw up the effective gap.
I'd put in another set.
Yes.
Hell no.
Nope.
MDchanic is offline
Old March 9th, 2014, 08:09 PM
oldrelics's Avatar
Yea, I was going to buy a new set, I was just trying this in the interim. BTW I have filed points on other vehicles with no
ill effects, prob just got lucky. Do you recognize the brake setup? What ever it came out of it mounts in the original bolt holes!
Old March 10th, 2014, 01:32 AM
lsutigers93's Avatar
Looks like someone upgraded to a dual MC from the old single...not a bad thing if done properly...
lsutigers93 is offline
Old March 10th, 2014, 06:13 AM
Looks like a dual M/C with a power booster from sometime in the eighties, but I can't say for sure.
MDchanic is offline
Old March 15th, 2014, 05:43 PM
Summerof84's Avatar
The vacuum setup, although not original, is correct. Some vacuum is supplied from the carb and the fuel pump supplies the rest. The booster/MC looks to be S10, which is exactly what I used on my '61 when installing the Scarebird discs conversion. My car has all the braking it needs, plus some now.
Summerof84 is offline
oldrelics
June 11th, 2014 10:23 AM
1961Olds98Holiday
Tech Editor's Desk
February 22nd, 2011 09:57 AM
1961Olds98Holiday
February 21st, 2011 04:15 PM
61SuperCoupe
August 15th, 2009 10:43 PM
61SuperCoupe
November 5th, 2006 10:46 AM
Quick Reply: 1961 olds super 88 questions 394
