What's it worth...2.41 10 bolt posi rear from 1976 Cutlass?
Old Oct 14, 2014 | 04:53 PM
Hurst/Olds 73/74's Avatar
I'm still scavenging parts off of the Cutlass junkyard find. I looked at the build sheet from the seats I bought last week and found that the car should have a posi unit. I went back today and sure enough, there's a posi tag on the rear and the glue outline under the trunk lid from where the posi decal used to be. The problem is, it's probably a 2.41 gear. Just wondered what it was worth and whether it's worth dragging home to resell...if the yard lets me have it cheap enough. The unit is complete drum to drum.
Old Oct 14, 2014 | 06:07 PM
gearheads78's Avatar
car guy
Worth scrap rate
Old Oct 14, 2014 | 06:13 PM
GEARMAN69's Avatar
IF you can get it for 50 bucks a usable 8.5 2 series Posi unit bare is still worth about a 100 without the housing and axles. Check ratio first it could be a 2.73 and would then be a 3 series carrier worth more. Whole rear end value as is about 200 and may have Bolt in Axles instead of C Clips so its a plus.
Old Oct 14, 2014 | 07:52 PM
The build sheet is what tipped me off to lift the car. The build sheet lists it as a 2.41 ratio limited slip. The car is a 1976 Cutlass Supreme Salon. The limited slip tag is still on the inspection cover, so I'm asuming it's the original rear.
Old Oct 14, 2014 | 09:25 PM
Originally Posted by GEARMAN69
...Check ratio first it could be a 2.73 and would then be a 3 series carrier worth more....
It is likely 2.41 gears, as listed on the build sheet I found in the seats. Does this mean it's a 2 series carrier and can't take 3 series gears, such as 3.21 and lower (numerically higher), or can I buy 3.21 gears and just put them in the 2.41 carrier?
Old Oct 14, 2014 | 10:31 PM
I think it would work the same as using a ring gear spacer on a 3 series to run 4 series gears.
Old Oct 15, 2014 | 05:44 AM
GEARMAN69's Avatar
if it is 2.41 Yes a common ring gear spacer kit can be used and comes with the long bolts (Mr. Gasket).
The correct series goes as this ...
2 series carrier and gears on a 8.5 is, 2.41 and 2.56.
3 series on 8.5 is 2.73, 3.08. 3.23. 3.42. 3.73 up yada.
There is no 4 series carrier on the 8.5 ,
12 bolt Type C Chevelle type have 2, 3 and 4 series .
G80 is the common build sheet RPO code but does not determine ratio, if no ratio is listed then its it is the standard equipment ratio.
Did it flat out say 2.41 ratio on the build sheet ? Sometime you get RPO code like GT4 or GU4 that is ratio related
Old Oct 15, 2014 | 06:45 AM
...G80 is the common build sheet RPO code but does not determine ratio, if no ratio is listed then its it is the standard equipment ratio.
Yes, the build sheet showed an RPO code and "2.41 Ratio". I'm at work now, but I can post a pic of the build sheet later tonight.
Old Oct 15, 2014 | 07:03 AM
GEARMAN69's Avatar
Thats cool, its really just a matter if the junkyard will sell the rearend cheap
Old Oct 15, 2014 | 02:57 PM
Here's the build sheet:
Old Oct 15, 2014 | 05:50 PM
GEARMAN69's Avatar
Cant open the link it goes to a 73-77 olds forum for the pic
Old Oct 15, 2014 | 09:13 PM
here:
Old Oct 15, 2014 | 09:19 PM
Ok, now I'm going to show my ignorance here...can I use the limited slip unit out of the 8.5 to make the factory rear in my 1985 442 a posi, or are the rear internals incompatible?
Old Oct 16, 2014 | 05:24 AM
GEARMAN69's Avatar
Thanks Yeah a GU1 code is 2.41 I see.
Your 85 442 should have a 8.5" 3.73 with 28 spline axles so Yes with a ring gear spacer kit your ring gear can go on the 2 series Posi and put back in , be sure your back lash and preload on bearings is close or same as it was when you take it apart.
Old Oct 18, 2014 | 02:01 AM
Redog's Avatar
Just sold one for $100
Was a 2.41 though
nj_cutlass72
Nov 20, 2019 09:11 PM
monzaz
Oct 2, 2012 04:49 AM
monzaz
Sep 11, 2012 08:27 PM
