steering stabilizer
Old Feb 11, 2023 | 03:56 PM
oldsmobilejim's Avatar
steering stabilizer
Hey guys, I can't find a steering stabilizer. I purchase one for my 68 442 many cars ago. The old JC Whitney use to carry them. Remember that store???
Old Feb 11, 2023 | 05:25 PM
70sgeek's Avatar
'72 Cutlass ragtop
You mean something like this ? https://www.oreillyauto.com/shop/b/c...rolet-chevelle
Old Feb 11, 2023 | 05:36 PM
There are universal units similar to that for Jeeps and other off-road vehicles.
My question is why do you want one / think you need one?
Old Feb 11, 2023 | 06:28 PM
I run two steering dampers on my 2003 Ford F250 because I have significantly larger oversized tires.
Old Feb 11, 2023 | 06:31 PM
Yep, my Jeep has one as well due to the much larger than OEM tires.
Old Feb 11, 2023 | 06:39 PM
I was pleasantly surprised with the dampening of the steering after installing the dampers. Really makes a pronounced difference in stability.
Old Feb 11, 2023 | 06:46 PM
If you have power steering, the stabilizer is a waste of money. Crank in as much caster as you can. That will provide "stability" and improved road feel.
Old Feb 11, 2023 | 06:50 PM
My comments (above) weren't suggesting any stabilizer/damper would yield any benefit to a 68 4-4-2 and I completely agree with you. My comments were just that - comments pertaining to my 2003 F250 diesel beast. (Just to be clear)
Old Feb 11, 2023 | 07:14 PM
I bet Norm rolls coal!
Old Feb 11, 2023 | 07:18 PM
No John. Nothing tricked out on the truck to roll coal. Just enough modifications to maintain performance and keep a 20 year old beast running.
Old Feb 12, 2023 | 08:23 AM
Meaning? Let's say 5 degrees positive is the spec., so we want more positive or negative. Are you saying going outside of the specs. Please exsplain???.
Old Feb 12, 2023 | 11:12 AM
The spec is about zero, which is the problem. This was done to minimize steering force, since manual steering was still an option. Kick the upper ball joint as far rearward as the available adjustment will allow. Modern cars run 4-7 deg caster, which is one of the primary differences in steering feel. If you can get more than 2 deg before hitting the limit of the available adjustment, you'll be doing great. I couldn't even get that much out of my 67 Delta, unfortunately.
Old Feb 13, 2023 | 05:25 AM
That's it Thank You.
Old Feb 13, 2023 | 05:38 AM
Ok I hear what you're saying and Thanks
riskyb
Sep 3, 2021 12:20 PM
abrasv
Mar 19, 2018 09:25 PM
White_Knuckles
Jun 17, 2013 02:41 PM
Aceshigh
Suspension & Handling
Jun 8, 2011 06:12 AM
Jolly Green
Apr 19, 2009 04:56 AM
