Any thoughts where I can buy a longer version of this bolt?
Old Feb 1, 2023 | 05:45 PM
v8al's Avatar
Registered Olds Owner
My Summit rod stretch gauge has a 1/4-28 by 1 inch socket screw that has a dog leg like appendage on the end to seat in the rod bolt dimple. See picture below.
Any thoughts on what this bolt is called and I where I could buy one that's 1 1/2" inches long?
Old Feb 1, 2023 | 06:03 PM
fleming442's Avatar
You can get a bolt/screw for cheap at the hardware store. If you have a friend with a lathe, you can turn the nipple on. Or, take both the a machine shop and they will duplicate it.
Old Feb 1, 2023 | 06:27 PM
Mr Shifty Sidney's Avatar
I would look at McMaster Carr they carry a lot of fastners. I do not know how accurate it needs to be but instead of turning the end of the bolt down, could you drill a hole in the end of a bolt and use a dowel pin as the nipple???
Don W
Old Feb 1, 2023 | 09:16 PM
edzolz's Avatar
As stated most hardware stores would carry a wide variety of socket head bolts. Tractor supply always has a stock on hand.
Old Feb 2, 2023 | 04:00 AM
BillK's Avatar
Can you show a picture of the end with the pin in it ? You might be able to pull the pin out and get a longer one instead of getting a longer bolt. I doubt you will find a screw with the pin already in it.
That being said it might be easier to just get a set of longer points for the dial indicator.
https://www.mcmaster.com/dial-indica...ce-indicators/
Old Feb 2, 2023 | 06:25 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I had a problem finding bumper bolts that were long enough when I had my 54. I bought some 1/2 inch allthread and cut a short pience. I put the bolt and the althread in my vise and took my Mig welder and tack welded them together. I don't know if that would work in your application or not.
Old Feb 2, 2023 | 07:22 AM
The bolt in the picture appears to be just a commercial allen-head capscrew with a pin pressed in the end of it. You'll need a lathe to accurately bore a hole in the replacement.
Old Feb 2, 2023 | 07:57 AM
BillK's Avatar
Just so you guys know what he is working on:
Old Feb 2, 2023 | 08:08 AM
4+4+2=10's Avatar
Thanks Bill, that visual helps a lot. As mentioned, a lathe is the most accurate way to replicate that configuration. If you have a drill motor and a bench grinder, you could chuck a bolt up in a drill and grind a taper point on the end of the bolt. It would look different, but still provide a small contact area and serve the same function as the fancy bolt tip.
Old Feb 2, 2023 | 08:11 AM
I suspect the pin on the original bolt is hardened. Not sure how much that might matter for this application. Good point though, that all this stretch gauge really needs is a centered point on the end of the bolt.
Old Feb 2, 2023 | 08:31 AM
BillK's Avatar
I think when its all said and done it would be easier to buy a set of tips for the indicator and be done with it. Not sure why he needs a longer bolt anyway. The tool is adjustable to fit any bolt I can think of. I have the ARP version.
Old Feb 2, 2023 | 08:58 AM
I'm not sure how to do a radius on lathe.
Old Feb 2, 2023 | 09:04 AM
BillK's Avatar
They make a radius tool for doing it.
Amazon Amazon
Old Feb 2, 2023 | 09:15 AM
Oh. That looks like it should work. Thanks.
Old Feb 2, 2023 | 10:43 AM
OLDSter Ralph's Avatar
A machinist could file and shape the radius with abrasive paper, using a radius gauge to confirm the radius.
Old Feb 2, 2023 | 10:45 AM
BillK's Avatar
It needs to be pretty precise and repeatable because it fits in a "dimple" in the rod bolt.
Old Feb 2, 2023 | 10:57 AM
I think a "skilled machinist" (not a machine shop guy) could duplicate it using a radius gauge set. I assume you mean less precise than checking it on an "Optical comparator".
Old Feb 2, 2023 | 11:27 AM
v8al's Avatar
FYI - Super tight clearance with the nut and the rod. (bolt bottomed out)
I'll probably remove the nut and just blue loctite the screw into the fixture.
It would have been better if they used a 1 1/2" bolt.
Old Feb 2, 2023 | 11:38 AM
v8al's Avatar
Closeup of bolt end.
Old Feb 2, 2023 | 11:49 AM
BillK's Avatar
That is tight. The ARP tool has a lot longer tip on that end.
Old Feb 2, 2023 | 05:03 PM
oldolds88's Avatar
cut the head off it,grind a slot in it and use a screwdriver to run it down lock with lock nut
Old Feb 2, 2023 | 08:37 PM
Mill the block enough to screw the "Jam nut" onto the bolt higher.
BillK.... Thats a nice unit, easy to handle and rigid.
Old Feb 3, 2023 | 03:13 AM
fleming442's Avatar
Now, y'all are brainfvcking it to death. Look at the ARP tool: it's just a point on a bolt. You could do that with a drill and a bench grinder. BUT, some people aren't happy unless they spend a bunch of money and overcomplicate things.
Dauntless1971
Drivetrain/Differentials
Dec 1, 2022 05:03 PM
Swisspeter
Feb 1, 2022 08:04 AM
king_doodle
Mar 13, 2018 08:52 PM
Tiha
Feb 3, 2018 12:00 AM
mcutlass1969
Mar 6, 2008 10:24 AM
