82 olds parking brake cable install
Hi everyone. I have a 1982 Oldsmobile Custom Cruiser Station Wagon. The parking brake cable from the pedal has seized. I bought a replacement. Does the left front fender have to come off in order to remove the cable?. The only thing holding me up is the rubber grommet that snaps into the sheet metal at the fire wall. Can't see it from the outside due to the fender being over top of it. Any help would be appreciated.
Well, you might consider using your favorite lubricant (PB Blaster, WD-40, Kroil penetrating oil) on the fasteners; as well as, the existing E brake cable. You might be able to free it and not need a replacement.
sheltonoil
Brakes/Hydraulic Systems
May 10th, 2017 08:13 PM
GoodOldsGuyDougie
November 22nd, 2010 08:07 AM
