69-70 Hood Differences
I have a 69 Cutlass S with a lot of hood rust and am looking to replace it before I have the car painted. I located a hood from a 70 Cutlass but can't quite tell in the pictures if they are different. The 70 has a trim strip down the center it appears. And looks flatter across the center. I just can't quite tell and hate to drive 1 1/2 hours to find out. Anyone sure about this?
Steve
Steve
Steve
Steve
1968 P/N 398409 is the flat hood
1968 P/N 398496 is the domed hood with the chrome louvers
1969 P/N 401758 is the flat hood
1969 P/N 401759 is the double hump hood
1970 P/N 404555 is the flat hood
1970 P/N 404556 is the double hump hood
1971 P/N 407257 is the hood without chrome louvers
1971 P/N 407256 is the hood with chrome louvers
This is the 1970 442 hood with the vents.
The stripes were
This is the front of the hood, twilightblue. The hood has no rust or corrosion. I had it in my loft for close to 49 years.
added.I know that it is dirty. I didn't wipe the dust off in advance of the photograph.
The flat hood used on the Supremes, F-85s, four doors and wagons (P/N 404555) looks like the photo below. Note that it has punched vents at the base of the windshield, not the chrome ones. Note also that this flat hood does not have the dip in the center the way yours does.
Thanks for all the info. I have the double hump with vents in the back. My car is in the body shop and their stripping it. I should know today if they think I should reuse the hood or not. At least I know the differences.
Steve
Steve
Joe,
I learned that a 442 hood is different from the Cutlass. I also thought that you were referring to a double hump hood as a way to distinguish the double hump from the W-25, which also has double humps.
I'm clear. My car was delivered with the W30 option. This gave me the W25 hood from the factory. When I raced, I removed the W25 hood to drop down one NHRA class and installed my "double hump" hood to lower my NHRA Class. Although the double hump hood is flat compared to W25 hood, the double hump is not as flat, and without humps as the truly flat hood.
I understand. Thanks for your photograph.
FYI: I was running the same E.T's and MPH with the double hump and without the air cleaner, as I did with my factory W25 hood.
I think much was marketing. The car was always a W30 regardless of the hood.
You rarely see '70 442's today with the double hump hood. Most have the W25 hood and W30 badges. In fact, isee more W30's today than I did almost fifty (50) years ago.
And the 2dr Cutlass S got exactly the same hood as the 442. The only difference was that the 442 hood was pierced for the Oldsmobile script at the front left and the Cutlass S hood was not. The sheet metal panel was otherwise identical. The parts book only listed the panel without the holes for the script. You needed to drill them to use it on a 442. Also note that while the F-85 2dr cars got the flat hood, in 1969 if you ordered an F-85 W-31, you got the double hump hood and the paint stripes. This is documented in the assembly manual. And yes, a certain bright green 1969 W-31 has a flat hood. Draw your own conclusions.
