what to do with W-30 intake after cleaning
Old March 23rd, 2019, 05:34 AM
yellowrocket's Avatar
Hi, looking for some insight as to what I should do with a W-30 aluminum intake after cleaning to keep it clean . I was thinking of some type of fuel resistant satin clear, but not to sure if there is a product that will not flake off or turn yellow when the enigne is run.
yellowrocket is offline
Old March 23rd, 2019, 07:02 AM
442Harv's Avatar
I would leave it bare. I tried spraying , with high heat clear, was not happy after a couple day, ended up taking it off.
442Harv is offline
Old March 25th, 2019, 08:56 AM
ronskal's Avatar
If you desire originality then you should keep it bare- it will be like my aluminum Edelbrock eventually.
I decided to paint mine with VHT aluminum color but not sure about applying the clear over it yet.
ronskal is offline
Old March 25th, 2019, 01:21 PM
zeeke's Avatar
I polished mine with Auto Sol aluminum polish. after about 2 years it's starting to need another cleaning. Since a had to pull the intake for a mangled push rod i'm going to hit it again before install.
zeeke is offline
Old March 25th, 2019, 02:13 PM
jozw30's Avatar
Got mine all cleaned up, used a “high temp” clear and the exhaust runners turned brown 3 minutes into the break-in......
Had to take it off, strip it and left it bare. Looks great 7+ years later. Use lacquer thinner on a white t-shirt to dab up anything that gets on it.
jozw30 is offline
Old March 25th, 2019, 02:22 PM
442Fred's Avatar
Have it vapor blasted and you wont need to paint it and it will look more like the original finish.
442Fred is online now
twillis004
July 27th, 2019 09:49 AM
dgp1042
July 12th, 2017 12:50 PM
joesw31
October 18th, 2015 09:26 AM
Anubis
January 13th, 2014 08:38 AM
my442conv
August 22nd, 2011 12:34 AM
Quick Reply: what to do with W-30 intake after cleaning
