Carriage bolt source
Old Apr 26, 2019 | 09:00 AM
deaddds's Avatar
Trying to find a 9/16 fine thread carriage bolt. Are these no longer made? Restoation supply doesnt even have them.
Old Apr 26, 2019 | 09:02 AM
RandyS's Avatar
You might check your local Ace Hardware. I have found them to have the best selection of nuts :& bolts anywhere.
Old Apr 26, 2019 | 09:27 AM
deaddds's Avatar
They only have course thread
Old Apr 26, 2019 | 03:15 PM
bw1339's Avatar
www. mcmaster. com
Old Apr 26, 2019 | 03:21 PM
OLDSter Ralph's Avatar
What are the carriage bolts going to be used for and how many do you need ? 9/16" bolts are not normally stocked.
Old Apr 26, 2019 | 06:05 PM
deaddds's Avatar
They are for mounting the rear bumper on a 63 Starfire. 1.5 inches long but could do 1.75. 4 bolts total but could take more if needed as they are used for lots of those full size
Old Apr 26, 2019 | 06:37 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Why would they have to be fine thread and I have never seem 9/16 bumper bolts. I need some 1/2 by about 3 (maybe 2 1/2) inch ones for the back bumper on my 54 Olds. I have finally concluded the only way I will get them it to weld or braze some 1/2" all thread to shorter bumper bolts and then cut it to the length I need. I will be doing that next week since I have some shorter bumper bolts. Good luck with your search.
Old Apr 26, 2019 | 06:57 PM
deaddds's Avatar
Supposedly fine thread allows for a better torque grip. Certainly the ones I pulled from the car were original and corroded enough to not risk reusing. Worst case I guess Ill use course thread.
Old Apr 26, 2019 | 07:00 PM
deaddds's Avatar
You dont have to weld them in. Go to OReillys and have them order bolt retainers. Thats what was used to hold the carriage bolt tight enough in place to be able to get the lock washer and bolt started. It also allows the bumper to be adjusted and not locked in place.
Old Apr 26, 2019 | 08:07 PM
Run to Rund's Avatar
Some bumper bolts have a square shoulder like a carriage bolt, but with a chromed head.
Old Apr 26, 2019 | 10:36 PM
Try Fastenal, McMaster-Carr, Grainger or some others. Fine threads are believed to remain tight in vibrational situations. Coarse thread and lock washers could work. Or get them longer and double nut them. Or, there is Loc-tite.
Old Apr 27, 2019 | 05:28 PM
redoldsman's Avatar
I am not intending to weld the bolts in the car. I am simply welding an extension on the bolt to make it longer since I can't buy one long enough. I bought a 1/2 piece of all thread about a foot long for less that $1.50. I already have the bumper bolts to add the length to. I will just braze a bolt on each end of the all thread and then cut them to about 3 inches. Done.
Old Apr 28, 2019 | 07:40 AM
Indy_68_S's Avatar
https://www.amkproducts.com/bulk-fas...oduct_ID=15004
Maybe ?
Coarse thread, but I wouldn't think bumper attachment is a high-torque high-vibration application.
Old Apr 28, 2019 | 10:15 AM
redoldsman's Avatar
Torque is not an issue on bumper bolts. They hold the bumper on. Put a lock washer on it and be done. There is really not a lot to this.
Lsx442
Aug 6, 2017 11:16 AM
Oldsragger
Apr 1, 2015 06:18 AM
denf221
Body work
Nov 3, 2013 05:13 AM
72CUTTY
Jan 20, 2009 08:00 PM
4fortwo
Dec 12, 2008 07:06 AM
