Wheel Cylinder Bolt?
Old Aug 6, 2017 | 06:15 AM
Lsx442's Avatar
I was inspecting the rear drum brakes on my car and found a leaking wheel cylinder... no big deal, pick up a new one and go to install it last night and I knew I was in for trouble when one of the mounting bolts felt too easy turn. Turns out the bolt was stripped but I was able to get it out.
Now I need a new bolt. Does anuoine know the specs on the bolt or a place I can pick up a replacement? If not I'll have to find something close at the hardware store
Old Aug 6, 2017 | 06:40 AM
You can just go to the hardware store and match a new bolt to the good one.
Old Aug 6, 2017 | 07:14 AM
These are extremely short bolts, so you will likely have to shorten one you buy.
Old Aug 6, 2017 | 08:58 AM
jensenracing77's Avatar
They are 1/4 x 20 I believe. If you are not worried about having an original bolt then just go to the hardware store like mentioned above. I believe they are 7/16 inch in length. If the shortest they have is 1/2 then just use a flat washer with it.
Old Aug 6, 2017 | 11:16 AM
Lsx442's Avatar
Thanks for the help. I'll try to get to the hardware store today.
Mike Sundy
Jun 6, 2016 05:53 AM
Del70
Jul 28, 2014 03:24 AM
coldfire
Jul 19, 2013 08:20 AM
ctrain22
Brakes/Hydraulic Systems
May 27, 2009 06:58 PM
rustyold66
Aug 14, 2008 07:34 PM
