wheel cylinder bore size
Old Aug 14, 2008 | 06:16 AM
rustyold66's Avatar
Anybody know the bore sizes for front/rear wheel cylinders for a '66 Delta 88? Checker Auto seems to have both the front and the rears available but it mentions multiple bore sizes.
http://www.partsamerica.com/ProductL...eel%20Cylinder
Thanks!
Old Aug 14, 2008 | 03:15 PM
Thanks!
Well, according to your link, there is a single rear bore size (1") and two front bore sizes (1 1/8" or 1 3/16"). If you're replacing both front cylinders, just get the larger ones. The additional piston area will provide a small increase in stopping power (which is why they were used on the police package), at the expense of slightly longer pedal travel.
Old Aug 14, 2008 | 07:34 PM
rustyold66's Avatar
wheel cylinder info
Duh - difference in bore sizes was front and rear. And I can use the police-spec ones with no issue? GREAT! I'm all for more stopping power. Thanks for the info - much appreciated!
Rick L.
hilbily
Nov 1, 2014 08:39 PM
crank shaft
Dec 30, 2013 03:29 PM
joepenoso
Jun 3, 2013 08:43 AM
jensenracing77
Apr 17, 2012 05:08 PM
defiant1
Mar 30, 2011 09:22 PM
