square bore vs spread bore
Old Nov 1, 2014 | 08:05 PM
hilbily's Avatar
Anybody ever run a square bore Holley on a spread bore manifold, did it work ok? Can it be run without an adapter plate?
Old Nov 1, 2014 | 08:11 PM
It will not mount without an adaptor, you'll have vacuum leaks. It's been done with an adaptor forever with success. I prefer going with an aluminum manifold setup for a square bore.
Old Nov 1, 2014 | 08:12 PM
Only if the intake manifold is drilled with a dual bolt pattern to accept either type of carb flange.
Old Nov 1, 2014 | 08:39 PM
hilbily's Avatar
It is drilled with a dual pattern, I was more concerned with sealing, it seems like it only has about a 1/4" around the secondary flange.
tru-blue 442
Oct 18, 2016 05:00 AM
Designosaur73
Jul 16, 2013 03:36 PM
jensenracing77
Feb 23, 2013 04:30 PM
HonestDave
Jan 5, 2013 03:34 PM
skryla
Apr 22, 2010 08:49 AM
