Question for a Hurst Dual Gate Expert
Old Apr 16, 2019 | 03:34 PM
w30brad's Avatar
Did Olds Dual Gate Hurst Shifters ever have the vertical etched line on the chrome stickshift like the one in this picture? The etched line on the stickshift would line up with applicable gear on the console gear indicator. For example, if you put the shifter in Drive, the etched line on the stickshift would line up with the D on the console gear lens plate.
I've seen a couple of these at swap meets. Did Olds ever use them as factory installed?
Old Apr 16, 2019 | 03:52 PM
72455442RA's Avatar
it looks like a 68 GTO shifter
I have had several of them
Old Apr 16, 2019 | 04:20 PM
w30brad's Avatar
Thanks. Doesn't the GTO have a straight stick,though? This one is curved.
Old Apr 16, 2019 | 04:52 PM
4speed455's Avatar
The GTO shifter does have a straight stick and the lower housing is different also. Your shifter looks correct for the 70-72 Cutlass/442. It also looks like this one on eBay that says it’s correct for 70-81 Camaro/Firebird. The Camaro shifter appears to not have the indicator line though.
https://www.ebay.com/itm/HURST-USA-R...7e13%7Ciid%3A1
My shifter does have the indicator line, unfortunately I am not sure of the original application as I bought it used and converted my console.
Old Apr 16, 2019 | 05:05 PM
w30brad's Avatar
Thanks for the reply, looks nice
Old Apr 19, 2019 | 05:48 AM
w30brad's Avatar
Anyone have a 1970 Factory installed W-26 Dual Gate that has the Gear Indicator line on the stickshift?
I have a 1970 W-30 with Dual Gate that appears to be Factory installed. It does not have the Gear Indicator line on the stick.
Old Apr 19, 2019 | 08:59 AM
I have one. Never noticed a line on the shaft, but I will look at it after work today to be sure.
Old Apr 19, 2019 | 08:23 PM
w30brad's Avatar
Sounds good Kenneth, thanks
Old Apr 20, 2019 | 11:13 AM
I verified that my 1970 W-26 option Hurst Dual Gate shifter does not have the line on the side of the shaft.
Note in the thread below that the aftermarket Dual Gate has the line. From this information, I would conclude that the original shifter handles did not have the line and the aftermarket shifter handles did.
https://classicoldsmobile.com/forums...ifter-f-s.html
Old Apr 20, 2019 | 12:13 PM
w30brad's Avatar
Yeah, that's what I've found Kenneth. Everything I've been able to find so far about the factory installed 1970 Olds W-26 (probably all '70-'72) shows no shift indicator mark on the stickshift
dz442
Apr 20, 2019 05:25 PM
Big Dawg
Drivetrain/Differentials
May 11, 2016 05:06 AM
bigblockchris
Jul 27, 2015 05:14 PM
dfire25
Dec 5, 2012 09:54 AM
