67 Cutlass AM/FM RADIO
Old July 17th, 2018, 06:25 AM
Keith Jones's Avatar
I want to test a 67 Olds AM/FM radio that I bought for my 442. I want to know the wire colors for the unit. My shop manual shows only BLK with a WHITE stripe. Also my radio has a harness with a 9 wire connector. I just need to know how is the best way to bench test this unit. My car doesn't have the mateing connector any more. I am only using the stock speaker locations.
Keith Jones is offline
Old July 17th, 2018, 06:50 AM
A stock 67 radio only has 3 wires. There's an antenna jack on one side, and a three wire plug on the other. I believe black wire in the car goes to the middle pin (you can see it is just connected to the chassis of the radio, and it is ground. Green in the car is power for the radio, and also the light, I believe. Blue in the car is the positive for the one speaker. If you have the biphonic speaker adapter, another harness, one blue wire, will be active, and it's the positive for the other speaker.
To bench test that radio. 12V THROUGH A FUSE to the positive, ground back to the battery, pos speaker out to the speaker, and speaker neg back to the battery neg.
A 9 wire connector sounds like positive power and 4 pairs of speaker wires. Could you put a picture of the radio up? I doubt it is a 67 AM/FM both from what you describe, and the fact that the 67 AM/FM A body Olds radio is expensive since there are so few so you probably have something else.
Koda is online now
Old July 17th, 2018, 07:35 AM
Randy C.
rcorrigan5's Avatar
The nine-wire connector sounds kind of like an am-fm STEREO unit, where the nine-wire connector goes to the multiplex unit, which would be separate from the radio. Without the multi-plex unit to complement the radio unit, the stereo aspect of the radio will not work.
Per what Koda said, the radio box is powered as he stated. But if the radio box you have is a stereo unit, you will only get sound (and just half the sound) out of the front speaker.
I always favored am-fm non-stereo units of that period, over the stereo units. It just seems to me that stereo reception with those early stereo units just wasn't that good. As well, with the non-stereo am-fm radios, you don't have to deal with the multi-plex unit.
Randy C.
rcorrigan5 is offline
Old July 17th, 2018, 09:06 AM
MI68442W30's Avatar
better check your info, I don't believe an AM/FM stereo was available untill 69 ,it was AM/FM mono untill then.
MI68442W30 is offline
Old July 17th, 2018, 10:23 AM
Randy C.
rcorrigan5's Avatar
My info shows an option code for model year 1967 of U58 for an AM-FM stereo radio. I don't see an option code for a stereo radio before the 1967 model year.
Perhaps the U58 option was not available for the A-body and just for the bigger cars?
Randy C.
Old July 17th, 2018, 11:07 AM
In the Olds A body, FM became available in 67. Might have been 66 in very low numbers. Big car radios do not interchange due to dash structure.
U63 was AM, U69 was AM/FM, and this was for all A bodies.
In big cars, U57 was stereo tape, U58 was stereo radio, U59 was wonderbar, U63 was AM.
I think he's got a either a big car stereo unit without the multiplexer, or a 70 A body stereo without the multiplexer.
The only way to get stereo with stock components in a 67 is to use a 66 reverb kit and drop some acid to make yourself believe.
Koda is online now
Old July 17th, 2018, 12:12 PM
I am including some pics that may help to identify my radio. I bought this unit years ago from a dealership's owner that had alot of old used parts.
I prefer the stock look versus the new state of art units.
Old July 17th, 2018, 02:37 PM
Randy C.
rcorrigan5's Avatar
Is there a sticker somewhere on the radio box that has a part number? That might help in determining where this radio belongs. The face looks very much like the AM-FM stereo radio in my '69 4-4-2.
The plug you took apart is definitely for the multiplex unit on an early AM-FM stereo radio ('67-'70 at least, and possibly '71). Somewhere in the '71 or '72 model years the multiplex unit was incorporated into the radio box and the extra box was no longer needed.
Randy C.
Old July 17th, 2018, 03:12 PM
Big car radio. Won't fit in a 442 dash due to the stuff on the sides.
Koda is online now
Old July 17th, 2018, 03:26 PM
Thanks the help and information. Aftermarket it is then.
Old July 17th, 2018, 03:43 PM
Well, there are alternatives. Some people buy the AM/FM. Some people buy AMs and have them converted to new guts and features. You may like that method, it would look stock, yet do cool tricks like connect to your phone.
Koda is online now
Old July 17th, 2018, 06:12 PM
I have thought about just getting a AM and hiding a streaming device somewhere.
Old July 17th, 2018, 06:16 PM
jeffsims's Avatar
I use redirad on my stock AM radio and love it.
https://redirad.com
jeffsims is offline
Old July 18th, 2018, 12:16 PM
wr1970's Avatar
I have one 1967 am with no ***** out of a cutlass. I am never going to use it.
wr1970 is offline
Old July 18th, 2018, 08:10 PM
4 Barrels of Laughs
quaddriver's Avatar
Location: I moved to pittsburgh so I can be near Primantis
that radio is missing the add-on for the speaker level fadery...any change there is a GM part number on it and I can pull up the service manual...
quaddriver is offline
matchek
October 22nd, 2018 08:33 AM
davoaz
April 20th, 2015 12:48 AM
FinallyGotIt
April 28th, 2014 06:07 PM
atomic13
October 18th, 2011 08:03 PM
olds67
April 18th, 2010 08:14 AM
Quick Reply: 67 Cutlass AM/FM RADIO
