information for radio mounting
Old Apr 15, 2010 | 12:28 PM
olds67's Avatar
hello guys
I bought an AM radio FM 67 Delmont , is very different from our European and I wanted to ask how to connect the wires.
which is the audio output?
thanks
Old Apr 15, 2010 | 03:38 PM
stevengerard's Avatar
looks like a 1970 AM/FM radio with the amp - I'll have to check but the blue and yellow wires are speaker wires I think. Maybe the 67 deltas had the same radio but wait until someone responds with a definite answer before you mess with the wires. I'll see if I can dig up my paperwork on how to hook it up CIAO
Old Apr 15, 2010 | 10:07 PM
Jaybird's Avatar
Yellow is hot! It's the power wire. Make sure it is connected to a fuse. Blue is the speaker wire. - Negative is ground. Do not run the radio without the speakers attached. The one blue wire from the radio goes to the front speaker.
The smaller unit is your multi-plexer. The blue wire from the multi-plexer goes to the rear speaker. These cars in 1967 had only two speakers. Stereo was achieved between the front and back speaker. There was no left & right stereo.
Make sure that... your radio, multi-plexer and speakers have a good ground.
Also, make sure that the base of your antenna is grounded to the fender or radio. Do not run the radio without the antenna hooked up.
This service manual helps a lot!
Old Apr 16, 2010 | 03:04 AM
Yellowstatue's Avatar
Is there a paper sticker with a model number on the side of the radio??
Old Apr 16, 2010 | 03:55 AM
olds67's Avatar
thanks Jay
the manual is for sale?
Old Apr 16, 2010 | 03:57 AM
olds67's Avatar
theres a sticker after you do the photo and put.
Old Apr 16, 2010 | 11:14 AM
olds67's Avatar
the radio is on and working!!!!!!!
Old Apr 16, 2010 | 01:22 PM
phew, glad you waited for an answer, looking at the image its clear the yellow was power, forgot both speaker wires are blue - mine is set up the same way, only two speakers, one in back and one in front.
Old Apr 17, 2010 | 12:32 PM
olds67's Avatar
i'm very happy,the radio is on and speackers have a good sound!!
olds67's Avatar
Old Apr 17, 2010 | 02:39 PM
Red Delta's Avatar
Registered Abuser
Why can't you run the radio without the speakers or antenna attached?
Old Apr 17, 2010 | 02:43 PM
olds67's Avatar
I make no mistake I connected everything as I read here, and it works.
Old Apr 17, 2010 | 04:01 PM
Jaybird's Avatar
OK: I was playing it safe. You could turn the radio on without the antenna.
From the 1967 Chassis Service Manual... 15-4 Trimmer Adjustment,
3. If the car is equipped with a rear seat speaker, insert a shunt wire as shown in Fig. 15-7 or Fig. 15-8. NOTE: Do not turn on radio unless shunt wire is installed.
Old Apr 17, 2010 | 04:04 PM
Red Delta's Avatar
Registered Abuser
Huh, that may explain why my radio didn't work as well after I disconnected the rear seat speaker and installed a modern speaker for my late model deck.
It's still in, perhaps I should disconnect the power to prevent the possibility of damage.
Old Apr 17, 2010 | 05:25 PM
Jaybird's Avatar
Hmmmm... Don't know about that... can't say for sure.
The instructions posted above are basically for trimming the antenna. Do you have a stereo multi-plexer? If it's plugged into the radio, you should have stereo sound. The speakers are 8 - 10 Ohms
Old Apr 18, 2010 | 07:27 AM
olds67's Avatar
Jay
this manual where can I find?
Old Apr 18, 2010 | 08:14 AM
Jaybird's Avatar
I got mine on eBay. There is one for sale right now. $49.99
http://cgi.ebay.ca/1967-DELCO-RADIO-...item53df89303d
I think I paid $20.00 for mine from some place in Saskatchewan, Canada.
I got a 67 Owners manual, 67 shop manual, and 67 sales brochure from these people... Good service! Kind of pricey.
They are located in Godrich, Ontario. Ask them to keep an eye out for a 1967 Radio Maunal. Say, 'Hi' to Nicola for me!
http://www.kenmcgeeautobooks.com/
dnmfranco
Jul 2, 2014 05:10 PM
dancutlass
Oct 2, 2012 02:49 AM
Redog
Jun 30, 2011 05:41 PM
sx455raidercelticfan
Jul 29, 2010 07:44 PM
<joyce>
Jun 11, 2004 12:16 AM
