Wire wheel tool
Old Sep 22, 2018 | 02:06 PM
Rick Old's Avatar
Wire wheel tool
Does anyone know if a plastic wire wheel tool will work on my metal locks?
I need a B.
Thankfully, Rick
Old Sep 22, 2018 | 06:14 PM
cherokeepeople's Avatar
never seen a plastic one.also there are about a half dozen different "key" wrenches,
Old Sep 22, 2018 | 10:53 PM
cjsdad's Avatar
I need a B.
Thankfully, Rick
If you are talking about the plastic "wire wheel tool" that comes in some of the rotary (Dremel) tool bit assortments, I have never been able to get any work time out of them at all before they fall apart. Even the real wire ones don't last long. If you are trying to restore the locks, try using Evaporust to clean them. Check out this thread to see what kind of results it can give. I have purchased two gallons and a plastic tub to start using it on my car parts too.
https://classicoldsmobile.com/forums...-body-off.html
Old Sep 24, 2018 | 07:06 AM
Weezer's Avatar
Jeff
He is talking about taking the wheels off his car. There is a special keyed tool for the nuts.
Old Sep 24, 2018 | 07:35 AM
cjsdad's Avatar
WOW! I sure went to the wrong place with that description.
Old Sep 24, 2018 | 02:55 PM
CRUZN 66's Avatar
Olds Fever
The OP is very vague in what he is looking for, but I believe he needs the letter "B" lock wrench to remove the wire wheel hub caps... Also need to know the make/model since Olds used two different wire wheel type locks - metal or plastic... For example, A-Body (Ciera) used larger plastic nuts and B-Body used a steel nut/bolt...
Old Sep 24, 2018 | 07:16 PM
It might work once.
Old Sep 24, 2018 | 07:18 PM
Rick Old's Avatar
It might work once.
I understand, thank you.
Old Sep 26, 2018 | 08:56 AM
Human's Avatar
Forward into the Past
I didn't know there was a plastic version. I used to have an '84 Buick Century (Ciera clone) that had a metal key tool to remove the wire wheel covers. I guess it was one of the little things that put Buick a notch ahead of Olds in GM's pecking order like having hydraulic lift arms for the hood instead of a prop rod.
Old Sep 28, 2018 | 12:00 PM
Rick Old's Avatar
Lock
Old Sep 28, 2018 | 02:01 PM
Rick Old's Avatar
Lock tool
The plastic lock tool does NOT work on metal locks!( wasted 35 bucks to find out, lol)
Old Sep 28, 2018 | 02:50 PM
Gerald Nickels's Avatar
I was at a Pick n Pull years ago and saw these two guys trying to get a wheel off and the could not get the hub cap of. I waited till they gave up then I used a screw drive and popped the center out then got all four tires. Reading this I remembers what I did years ago.
Gerald
Old Sep 28, 2018 | 02:54 PM
Rick Old's Avatar
Lock
Yes, got all mine off with needle nose vice grips. I am thinking about just taking the locking nut off the hub caps forever, and not worrying about it anymore. It's just three tabs that hold the locking nut to the caps anyway .
friesjh
Sep 18, 2019 07:09 PM
Rick Old
Sep 23, 2018 06:02 AM
Macadoo
May 5, 2014 05:29 PM
Icee5150
Sep 1, 2013 10:16 AM
stetzie
Jun 24, 2011 09:39 AM
