Front disc to fit 14" drum rims on 64-72 Cutlass, 442
I have had a few Olds A bodies, my favorite being a 66 442 ragtop 4 speed. It always vexed me that those wonderful Super Stock I rims could not be fitted with disc - till now.
We doped out a way to fit a 2-1/2" inch bore caliper and 10-1/2" rotor inside the stock drum wheels, including poverty wheels. This, coupled with a 7/8" bore master from a 75-80 Starfire will give you far superior stopping power compared to drum. What we need to know is if there is a demand for this now? A wheel kit would run around $800 US... some pix:
As you see, the rotor mounted to the inside of the hub, like some 4WD and FWD. The wheels are pushed out only 3/16" of an inch versus stock drum. The rim shown was from a 65 Cutlass and had a pie slice taken from it...
Clever idea and I like the solution. The drum brake wheels is why I haven’t converted to disk brakes. This solution would be right in line with what is like to do since I’m not required to buy new wheels
Bglad
Brakes/Hydraulic Systems
April 19th, 2015 11:25 AM
