Front disc to fit 14" drum rims on 64-72 Cutlass, 442
Old October 2nd, 2018, 09:29 PM
Disc brake guy
Scarebird's Avatar
I have had a few Olds A bodies, my favorite being a 66 442 ragtop 4 speed. It always vexed me that those wonderful Super Stock I rims could not be fitted with disc - till now.
We doped out a way to fit a 2-1/2" inch bore caliper and 10-1/2" rotor inside the stock drum wheels, including poverty wheels. This, coupled with a 7/8" bore master from a 75-80 Starfire will give you far superior stopping power compared to drum. What we need to know is if there is a demand for this now? A wheel kit would run around $800 US... some pix:
As you see, the rotor mounted to the inside of the hub, like some 4WD and FWD. The wheels are pushed out only 3/16" of an inch versus stock drum. The rim shown was from a 65 Cutlass and had a pie slice taken from it...
Scarebird is offline
Old October 3rd, 2018, 06:55 AM
Dave26's Avatar
Does this kit use "A" body drum or disc spindles?
Dave26 is offline
Old October 3rd, 2018, 08:03 AM
Disc brake guy
Scarebird's Avatar
Original drum, I should have mentioned that...
Old October 3rd, 2018, 01:43 PM
72 Olds CS
RetroRanger's Avatar
thats pretty cool, idont need that but i can see where it fits a need
RetroRanger is offline
Old October 3rd, 2018, 01:54 PM
Gary
VC455's Avatar
Beautiful concept and execution. Nice machine work.
When I put discs on the back to fit SSII wheels, I had to make some adaptations, but your work is a lot prettier!
VC455 is offline
Old October 3rd, 2018, 06:10 PM
Lsx442's Avatar
Clever idea and I like the solution. The drum brake wheels is why I haven’t converted to disk brakes. This solution would be right in line with what is like to do since I’m not required to buy new wheels
Lsx442 is offline
Old October 3rd, 2018, 10:20 PM
There are 4 types of SSI. Only one does not fit disc brake. The ones with the trim rings are the most popular ones that do.
Koda is offline
griffey57
October 9th, 2016 03:47 PM
Bglad
Brakes/Hydraulic Systems
April 19th, 2015 11:25 AM
LI Olds
January 14th, 2013 02:26 PM
Ablast
May 21st, 2012 07:34 PM
oldgold
May 16th, 2012 01:58 PM
Quick Reply: Front disc to fit 14" drum rims on 64-72 Cutlass, 442
