Box of stuff, previous owner
Old Sep 19, 2018 | 02:59 PM
yellowone's Avatar
Received this box of stuff from the previous owner. Inside was this distributer marked CARDONE REMANUFACTURED. One, is it a 350 Oldsmobile distributer?? I have nothing to go by because the current one has an HEI in it. This one looks quite a bit shorter than the HEI. All you wonderful pro's out there help me out is this a Olds 350 distributer and the brand good, bad, no difference as long as it works? Opinions please. Of note, the camshaft gear shadt is 6 sided as shown in the third pic.
Old Sep 19, 2018 | 03:09 PM
Hard to tell if it's a "350" distributor without looking up the number stamped on the body and correlating that to the original application.
An Oldsmobile distributor will basically fit into any second generation Oldsmobile engine - 260, 307, 330, 350, 400, 403, 425, 455.
Old Sep 19, 2018 | 03:17 PM
In your first picture there's a number stamped onto the side of the distributor housing - starts with 1111 but can't make out the rest. Post that and I'll see if it's in the parts manual.
Old Sep 19, 2018 | 04:34 PM
yellowone's Avatar
All that is visible on the distributer is the four 1111 rest of numbers unrecognizable.
Old Sep 19, 2018 | 08:36 PM
70Post's Avatar
They probably removed the numbers when it went through Cardone's process.
1969camaross350
Feb 27, 2022 02:25 AM
Bee Saint Louis
Oct 15, 2018 06:58 PM
OldsAl
Jul 31, 2017 10:35 AM
MX442
Mar 25, 2012 01:00 PM
B-Mann
Aug 1, 2011 06:30 PM
