build sheet help
Old Oct 26, 2018 | 05:53 AM
mattking's Avatar
build sheet help
Does anyone know what I am missing on the damaged part of my build sheet. I'm just curious in general, but also specifically, I am wondering if my car would have come with the ram air hood, which I believe is an original hood, perhaps not original to my car.
Old Oct 26, 2018 | 06:01 AM
jharsh's Avatar
Matt,
Not sure what is missing of the side, but I would think if the OAI Hood was original to the car it would have W25 option code in the list of options and your does not appear too. Hope this helps.
Old Oct 26, 2018 | 08:13 AM
vette442's Avatar
Originally Posted by jharsh
Matt,
That's correct - the codes are alphabetical and W25 would be in the last column, which is intact.
Terry
Old Oct 26, 2018 | 10:25 AM
mattking's Avatar
I see what you mean now. For some reason I was thinking it would be in one of the boxes.. Thank you guys very much.
Old Oct 26, 2018 | 10:28 AM
hurst68olds's Avatar
I agree with the above
lower left would've been dealer information
above that, options & accessories alphabetically before B30
above that, tire & paint codes
Old Oct 27, 2018 | 07:06 AM
Of course, an original hood would also have a screen on the underside. This one doesn't and is likely a repro.
Old Oct 27, 2018 | 02:15 PM
asx455's Avatar
Alan Reedy
As stated previously, the only thing you are missing from that section of build sheet is the original destination dealers information. However, if it was absolutely necessary, the dealers zone and code number are partially present and you could possibly obtain that information through that means. The dealers number looks to be either 351 or 851. The zone has what appears to be a 4 which could possibly indicate zone 24 which is Southern California. Although I am unaware of any database that has these codes listed for Oldsmobiles, some other GM makes (especially the Corvette guys) have their dealer codes searchable, and someone "might" get lucky enough if they spend the time doing some research, to find their code at a dealership that sold multiple name plates, ie; Billy Bobs Chevrolet Oldsmobile or Orvills Olds Pontiac or similar. Overall, it's not that important. With regards to your hood, it is definitely an original hood from GM but NOT original to that car from the factory. Hope this helps.
matt506
May 30, 2019 06:40 AM
sevntyW30auto
Dec 26, 2018 03:32 PM
jharsh
Jun 29, 2017 12:05 PM
Blackpage
Apr 25, 2016 03:07 PM
arrowhead
Mar 6, 2015 07:03 AM
