Proper Posting Etiquette & Procedures
Old May 27, 2020 | 12:17 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
As a longtime member, I have some information/suggestions to pass along to the masses to help us all provide a better service.
The object of posting here is to receive tech help, sell something, find something, ask a question et. al. I realize most of us are not English majors and some are not from the USA. Many simple spelling/grammatical apps are available to assist. They are generally free. Here's one---> (Grammarly).
To the point. Reading many posts can be time-consuming, hard to understand, and or follow. The reasons are many. I write bi-lingual SOPs and Work Instructions. They need to be simple to-the-point with good grammatical structure and not long in the tooth(I'm guilty of this one but I am a work in progress). I should be able to hand any layperson one of my SOPs/WIs and they should be able to perform the task with little effort knowing nothing about the subject.
To that here are some general posting suggestions and basic etiquette. (Sticky?):
1. List the basic information about your car: year, make, model, engine, and transmission. List any and all modifications or recent service work. How many miles on it? Include the VIN & Cowl firewall tag data.
2. A picture or video is worth 10,000 words.
3. DO NOT TYPE IN ALL CAPS AND OR ALL BOLD. IT MEANS YOU'RE YELLING AND IT'S HARD TO READ!
4. Do not type one large paragraph. Split it up into sections. It's much easier for the brain to read when sectioned, spaced, or bulleted. You have plenty of room use it.
5. Stick with standard font sizes and styles. Calibri or Times New Roman sizes 11 or 12 or even 14 for us Oldsfarts who can’t see.
6. Proof-read your post to catch any obvious errors before hitting the Post Reply box, thou you can edit afterward if needed. If you are a registered member the Go Advanced box will allow you to preview your post to see what it will look like before it officially posts.
7. Make the post title direct to the point with few words. (helps the search engine).
8. Do a little upfront homework. If you don’t know what the doohickey kabobulator muffler bearing thingy is, do some Googling. Pop boom bang click slap tap thwack squeak are great expletives but are worthless without pics & vids.
9. Always conclude or follow up on your post when you find the problem. This will help the next person and prevent redundant post of the same problem.
10. Google is 1 to the 100th order more powerful than the search engine here. Google your question and 9 out of 10x it takes you directly to Classic Olds.
11. Read classified section rules. Look at for sale section before placing a want-ad. When parts or cars are sold mark them as such in your post. Don't delete it or remove the pricing. We need to preserve the history.
Primary effect: The easier your post is to read the more likely someone will be willing to read it and answer the question. So spoon-feed it. Laziness induces slow responses.
Secondary effect: All search engines will work better.
Tertiary effect: Lower frustration levels for our senior members and Oldsfarts tired of explaining the false nuclear 1/2 life legend of the 70-72 C/S engine offset for headers!
We now return you to your regularly scheduled program.
Steve
Last edited by droldsmorland; Jun 2, 2020 at 11:13 AM. Reason: had to fix your to you're per Koda. This will be a work in progress
Old May 27, 2020 | 12:41 PM
Suggested edits:
"IT MEANS YOUR YELLING AND ITS HARD TO READ!" That's 'you're'
Put "classicoldsmobile.com" in the google string to search just the site.
Put a link to the for sale ad rules. Perhaps emphasize location, setting a price, and not being condescending with "$5000 and NO LESS! I KNO WUT I GOT!"
Old May 27, 2020 | 01:03 PM
Also, use some punctuation so that your paragraph is not just one long run-on sentence.
Old May 28, 2020 | 09:40 AM
Good catch. Surprised Grammarly didn't catch this one? Hey its a 99.9% app. Thus, the reason I always employ someone else to proof before publishing. My eyes certainly glazed over.
Instead of adding a link to the classified rules, there should be a one-stop-shop that new users are directed to that gives all of this general info in one spot.
People are more likely to actually read it if it's in a single location and a quick simple read.
Another suggestion: before posting a want ad, read the for sale ads first.
Countless times I see a want ad for a part and a seller is selling one right next to it.
Old May 28, 2020 | 02:23 PM
twilightblue28A's Avatar
Doc,
Good points. What is a "SOPs/WIS?"
Thanks.
Old May 28, 2020 | 07:26 PM
BackInTheGame's Avatar
SOP = Standard Operating Procedure These may also be referred to as "MOP's," or Method of Operation
WIS = Work Instruction Set
These are clear and concise, often displayed in an "If This, Then This" tabular format. They include a Title Block of specific info about when the SOP is written, the intended Audience, required Preparatory work, Author info, required review/update period, etc.
1. "Do this," expect this result
2 "Do this," expect this (new) result
3. "Do this," expect this (new) result
X. "You should see this end result."
(Done)
One sample
Old May 28, 2020 | 08:10 PM
It does not matter how, how many times, or where you post, there will always be someone that will not look, cannot comprehend, or thinks they are special.
Old May 31, 2020 | 12:34 PM
So true Eric.
But if it was a requirement to read a condensed version of the above before being allowed to proceed with a new post it would/could go a long way.
Not sure how IT makes that magic work? I do know of a few sites that have these roadblocks which force it. It needs to be really basic and very short.
Part of the fun here is answering people, though it can be frustrating when basic etiquette and grammar are excluded.
Old May 31, 2020 | 12:45 PM
Here is one example:Welcome, New Member,
Thank you for joining X Bid site. Our home page is located at: XXXX
X Bid offers a variety of information to help you learn how to effectively use our system:
  • Before bidding on an item we strongly recommend that you read our Buyer's Tutorial.
  • To learn how to sell items, please review our Seller's Tutorial.
  • To review our fees for listing and selling items, see our Fees page.
  • Do you want more detailed information before you dive in? If so, head over to Basic Training.
  • Browse our Customer Help Center, which contains resources designed to help you use our auction site and report problems.
Thank you,
Administrator.
Old May 31, 2020 | 01:40 PM
I don't think that's necessary, for some this site is complicated enough. Have you ever clicked on the FAQs tab above?
Old May 31, 2020 | 02:57 PM
ya prob right.
like to help when I can
The link in the FAQ doesnt work for me?
Old May 31, 2020 | 03:59 PM
ya prob right.
https://classicoldsmobile.com/forums/faq.php
Old May 31, 2020 | 06:31 PM
Thanks Eric. That works!
Steve
Old May 31, 2020 | 07:49 PM
KW5413's Avatar
On the flip side, every site has long standing members that think they are special.
Old May 31, 2020 | 08:44 PM
People who have been here a while are known and trusted. Stick around and you will be, too.
Old Jun 1, 2020 | 05:52 AM
AJFink's Avatar
Is there a way that when something is sold that the post can go to a sold section rather than still being active. Sometimes I have to go half way thru a post to see that is already sold.
And if this could be done for the wanted section as well.
Old Jun 1, 2020 | 12:57 PM
No, because the classifieds are basically forum threads. People should update their threads mark parts sold to let others know they are no longer available. Do not edit out the descriptions and pricing, just mark them sold so we can keep a history.
Gawain
Site Help
Dec 15, 2017 07:58 PM
Cruizin Uncle Bob
Site Help
Aug 17, 2017 07:12 PM
Alacrity
Site Help
Mar 20, 2017 01:11 PM
bspaulding
Jun 1, 2015 08:41 PM
stratoblues
Aug 19, 2012 07:52 PM
