Transmissions first to second generation 88
Old Sep 1, 2023 | 03:29 PM
KCRocket88's Avatar
I have an opportunity to buy a 4spd auto trans out of a 1950 rocket 88, but I have a 1957 88 with a 371ci w/an 4sod auto. I know the first gen had a 303 block. Are these trans interchangeable?
Old Sep 1, 2023 | 06:24 PM
Charlie Jones's Avatar
Phantom Phixer
Not really.
While the '50 trans will bolt up to the '57 block, the flywheel and crankshaft must be modified.
The '57 and up 371 & 394 engines are " Offset balanced ".
Which means that weight is actually added to one side of "the flywheel to help balance the crankshaft.
The '50 flywheel must be modified with this weight and the engine re-balanced.
The '50 flywheel is smaller than the '57 so a '53 or earlier lower bellhousing and '53 starter (12 V) must be used.
Finally, the '50 trans employs a pilot bushing in the end of the crankshaft like a stick shift.
The crankshaft must removed from the engine to be machined to fit this pilot bushing.
G Boss
Apr 21, 2022 04:17 PM
Jeff99
Nov 27, 2020 04:19 PM
navvet
May 23, 2013 06:55 PM
christl
Aug 11, 2010 01:35 PM
craftsman1956
May 2, 2010 10:31 AM
