frame restoration
Old Jul 9, 2023 | 06:02 PM
servexcell's Avatar
frame restoration
I am having the frame from my 68 Convertible restored. No metal work need just sanding and priming and paint.Just to note it has alot of pitting What kind of pricing should i look to spend
thanks Bruce
Old Jul 9, 2023 | 07:57 PM
Rallye469's Avatar
Need a few more details.
Are they pulling the body off and disassembling all the chassis components?
Or are they just sanding what they can get at and painting it?
Old Jul 10, 2023 | 04:24 AM
Also need to know what kind of car it is. Is it a 68 Cutlass?
Old Jul 10, 2023 | 02:20 PM
servexcell's Avatar
68 Cutlass frame was already sandblasted and painted a few years ago. I just had it restoed again show car finish. frame all dissasembled.
thanks Bruce
Old Jul 10, 2023 | 04:36 PM
VI Cutty's Avatar
Is the pitting from after that last sandblasting and painting? Any new rust on the frame? Sounds like you want someone (a body man?) to use filler to smooth things out and wind up with a finish to match the quality of the car's?
Old Jul 10, 2023 | 05:03 PM
Sugar Bear's Avatar
No idea on the $$$, sorry. Curious though, was the frame measured for twisting/racking/bends etc.? If yes was it out of spec by much?
Thanks,
Old Jul 11, 2023 | 10:15 AM
Bernhard's Avatar
Thanks,
X2 if you have not measured the frame yet it is very important to check before proceeding. I have seen it to many times when the car was being reassembled that the frame had issues. Now is the time to ensure the frame is true.
Good Luck
Old Jul 11, 2023 | 01:02 PM
cdrod's Avatar
Rodney
^^^THIS IS VERY IMPORTANT^^^
If you've gone to the trouble of removing the body from the frame for your restoration, you should take the frame to a frame shop and have them check it for straightness, twisting, and sometimes the engine crossmember sags. I'm in the process of reassembling my car *frame-off resto" and I did not check the frame - big mistake! I could not get the core support or the front bumper to fit properly during reassembly, I finally took the car to a frame shop where they straighten the front frame ears (where the bumper mounts) and removed a twist that made the right rear sit higher than the left side. It would have been much easier to correct these issues BEFORE the body was back on the frame. Just my 2¢.
Rodney
Old Jul 12, 2023 | 06:22 AM
servexcell's Avatar
thank you for responding. Very good point to have it checked for straitness ,. The shop who is restoring the frame had checked and it is ok. Thank G-d as it is costing a small fortune to have it painted.
Bruce
68Oldswife
Dec 19, 2023 11:51 AM
KcPaul
Aug 21, 2022 09:47 AM
lala5818
Feb 2, 2021 04:59 PM
ed nice
Feb 22, 2016 10:20 AM
oldspackrat
Dec 21, 2012 08:27 PM
