Wanted, 1968-72 convertible frame, chassis, not top frame.
Old Dec 21, 2012 | 09:08 AM
oldspackrat's Avatar
I've got a friend here in Indianapolis that is almost done with the restoration of his 1968 Cutlass convertible only to discover that his frame has been damaged in the front & rear. So he is wanting another complete frame, minus suspension parts. I told him I'd put up a post & see what happens.
Thanks.
Scott
c. 317-727-7041
Old Dec 21, 2012 | 10:21 AM
69442C's Avatar
Since he already has a conv frame, I would look for a HT frame and cut out the box pieces from the conv frame and add them to the HT frame. To do so he will need to remove from the HT frame the small braces in the center of the side rails. He'll end up with a conv frame, almost identical to an original, for a fraction of the cost. If his boxing pieces are not good, then look for a 69-72 Pontiac GP as they have boxed frames and the boxing pieces are the same as the A Body cars.
Brian
Old Dec 21, 2012 | 10:25 AM
Brian,
Good point, I should have thought of that. With that being said, I guess we're looking for a convertible or hardtop frame now.
Thanks.
Scott
Old Dec 21, 2012 | 10:40 AM
69442C's Avatar
Scott,
I rembered seeing this several weeks ago and I thought his price was more than fair. He's in Erie IIRC so the distance may not be too bad if it's still available.
Brian
https://classicoldsmobile.com/forums...442-frame.html
Old Dec 21, 2012 | 07:33 PM
ent72olds's Avatar
Registered Luser
Scott, check with WTony....he may have what you need!
Old Dec 21, 2012 | 08:27 PM
507OLDS's Avatar
Scott,if you convert a hardtop frame,you should have one under one of your parts cars.
oldspackrat
Jul 20, 2022 07:34 AM
oldsmobilty
Sep 27, 2012 04:26 PM
cfair
Jun 30, 2012 10:07 AM
Olds luvr
Dec 2, 2010 08:26 AM
real442
Cars Wanted
Jan 23, 2008 04:02 PM
