Am I doing this right? I'm trying to adjust the door gaps on my 72 Vista
Old Oct 21, 2017 | 01:52 PM
tcolt's Avatar
I want to widen the gap at the top and bottom front edge because the belt line corner is rubbing inside the fender when I open the door. Is this as easy as loosening the three bolts each at the top and bottom of the a-pillar? I did that and I'm not really getting enough easy movement. I got the top to widen, but after that I loosened the lower bolts and lifted the rear of the door and it won't lift. I checked the useless assembly manual and can't find anything on doors and I did a search on this site too.
Thanks, Tom
Old Oct 22, 2017 | 05:37 AM
Rustbucket2's Avatar
Are you sure the fender doesn't need to come out a small amount to make room for door to open!
Old Oct 22, 2017 | 08:19 AM
tcolt's Avatar
I'm not sure, but the door was already slightly further in than the fender at the upper edge and the gap on the other door is also quite a bit bigger at the front gap. I'm pretty sure I have it loose. I guess I just wanted to make sure that the hinges or doors have oval adjustment slots like other cars where you can move the doors relative to the hinges that would allow me to lift and lower the rear edge of the door. I really don't see any other way to do it unless maybe they use some kind of shims...
Thanks, Tom
Old Oct 22, 2017 | 04:55 PM
Here are pics of adjustment plates, the sat inside the door jam under A Pillar and also inside doors. they move up, down, and around. Not oval, but square. hope this helps
Old Oct 22, 2017 | 06:15 PM
tcolt's Avatar
Ok. Excellent. So, I should be able to pretty much adjust the way I thought. Odd, because I had the bolts fairly loose. Usually, after I widen the gap at the top, I kind of tighten that end, but not so firmly and then loosen the bottom hinge to bring the door up again, while using the slightly tightened hinge as the rotating point. Maybe I had it a little too tight... Thanks for the pointers and pictures....
Old Oct 22, 2017 | 06:19 PM
tcolt's Avatar
Since it looks like you are restoring your car or have done so. Do you have a source for the original beige fiber mats (roughly 1/8"?) with the plastic foil backing that they used on the floor boards? I know most people probably replace it with a newer type of bitumen or other insulation, but I still like keeping things like they were and my original insulation isn't really good enough to go back in the car.
Rocketbrian
Body work
Jun 14, 2015 05:45 PM
dc2x4drvr
Body work
17
Apr 5, 2014 06:55 PM
JuzCallMeDee
Body work
Feb 27, 2013 07:15 AM
Del70
Jul 7, 2011 09:35 AM
Oldsguy
Nov 28, 2010 12:31 PM
