TSC switch
Old Oct 3, 2017 | 04:33 PM
Zr1bandit's Avatar
TSC switch
How do you go about eliminating the TCS switch inside the transmission. The switch has been removed inside the tranny and wondering if i need to ground the wire from the TCS solenoid on the intake to allow the system to operate as if the switch were in the open position allowing full advanced at all speeds. Do i just need to ground the lead down where it connects to the tranny. Thanks----------Greg
Old Oct 4, 2017 | 05:33 AM
If you simply disconnect the wire to the TCS switch, the system will provide vac advance at all times. The switch actively grounds the solenoid valve on the intake when the trans is in any gear other than high. You can also simply disconnect the power wire to the solenoid valve - same effect.
Old Oct 4, 2017 | 07:14 AM
Zr1bandit's Avatar
Thanks Joe, So i just simply disconnect the wire going to the switch in the tranny and im good to go--thanks. again. Greg
CroixDad
Mar 25, 2013 11:14 AM
19will
Nov 4, 2012 02:22 PM
mikemickunas
Sep 12, 2012 07:15 PM
Delta88Vert
Aug 12, 2012 11:39 AM
