Holley 4160 rebuild ?
Old Nov 8, 2017 | 08:37 AM
70 ctls's Avatar
Hi Guys,
Much of what makes me tick in my retired situation is tinkering with my Oldses and carbs for them. My question is: What is the proper way that Holley designed the seal between the main bodies 'accelerator pump passage' and the metering block? This apparently is an earlier model which does not have the transfer tube and 'o' rings on either end.Please note arrow which shows to what I am referring
In one spec sheet on a 4165, it refers to inserting roll pin and 'o' ring over it flush. Other than that I Have found nowhere mentioned how to seal it on an early model 4160. Know that without something there it runs poorly or not at all
Old Nov 8, 2017 | 11:37 AM
Gasket #55 perhaps? It appears there is a hole in the gasket that aligns with the pump passage.
Gasket #57 also has (or should have) a hole for the accelerator pump.
I once got a Holley 600 for $5 because someone used the wrong gasket in the #57 location - used one with an open area instead of a hole to seal the port. Someone rebuilt it and it had no pump shot, so they turned it in as a core and bought a reman carb. I was able to get the Holley for the core charge, installed the correct gasket, and ran it on my car for a while then on my friend's '67 Camaro after that.
Old Nov 8, 2017 | 01:17 PM
70 ctls's Avatar
Fun71,
You make a good point I may have overlooked. I haven't broken the carb down yet but will bet the #55' gaskets are as you stated 'open hole' ones. Therefore I thought an 'o' ring of sorts was the answer. I guess it requires me to rip it apart and find the right #55 gasket. That makes sense! I guess the more open gasket is meant for the later model versions that used the transfer tube with 'o' rings that I referred to earlier. I'm in know rush or need because the car is running with another carb at the present time. At sometime, however, I will follow through. For me , learning about the fix is key.
Old Nov 8, 2017 | 01:27 PM
cherokeepeople's Avatar
but if you look at part 102 the secondary metering plate above the hole where the power valve goes it is recessed so if the #101 primary metering plate is the same it wil not sandwich that gasket very good and could leak
Old Nov 8, 2017 | 04:32 PM
70 ctls's Avatar
OK...... So here's what I think is going on.
The gasket to the left is the one I should be using on the primary metering block to body. Got a feeling I"m using the middle one ( which I think is provided for the later models that use the transfer tube with o rings on both ends for seal). Correct me if I'm wrong, the gasket to the right is for the secondary metering block.
Old Nov 8, 2017 | 06:47 PM
That is how I ended up buying the Holley 600 for a $5 core charge - wrong gasket was used in the rebuild.
Old Nov 9, 2017 | 03:43 AM
70 ctls's Avatar
Thanks to all. Can't wait to rebuild!!
350TurBRO
Aug 14, 2014 08:12 PM
jag1886
Mar 6, 2012 09:44 AM
g77rvd
Apr 7, 2011 09:34 AM
g77rvd
Mar 26, 2011 02:55 AM
