1968 Cutlass Supreme Wheel Question
Looking for some advice here...I have a 68 CS with the factory 14s and I am looking to upgrade the wheel and tire size. Of the 3 (15", 16" or 17") what is the biggest size & width (7" or 8") I can put on and do nothing but bolt them on? I don't want to have to modify anything, just give it a different, more "beefy" look.
My '68 came with the 14x6 SS2 wheels,way to small in my humble opinion! I went with 15" SS3s, done in the '69 H/O style with the argent painted center with chrome rims from Coker. They are 15x7 front/15x8 rear. I used 235/60s on the front & 275/60s on the rear. I have no issues with rubbing. Unfortunately Coker no longer sells them but I believe they still have the chrome/black SS1s in 15" sizes. My next choice would have been Cragar SS 15s, they look good on anything!!
I'd assume the 68' is similar to the 71' so if that is the case you have no clearance at the back of the tire but you could get away with an 8" wheel as long as it comes out towards the wheel well. If you are looking to stay stock and cannot find them there is a company in MI that widens stock rims. I looked into it, $30 to ship each way each rim and if memory serves me correctly, which is rare the older I get, it was $120 each rim to widen.
I get the idea on what you’re saying, but I’m not terribly technical and it is sort of Greek to me was well. Ha. So if I wanted to go with a 17” wheel you’re saying it’s more of a tire size issue rather than the actual 17” part?
I have Wheel Vintiques on my 68 CS. They are Olds SS1 reproduction wheels, 15X10 with 5 inch back spacing. Tires are BFG Radial TA's 295/50 R15. Nice and fat but maintains 26.6 inch height.
They look and drive great. 15X8 and 235/60 R15 in the front.
These wheels look like the original Olds SS1's. You have to look closely to determine that they are not the original 14 inch. Your original center caps will fit.
I have no issues with rubbing unless I have 2 back seat passengers and only during a dip or corner.
Steve
https://www.wheelvintiques.com/wheel...obile-ssi.html
Steve
Steve
Steve
Nice Supreme Steve!! That brings back lots of memories. My first car (mom's hand me down)was the same saffron/black combo like yours except it had the silver lower body color(never cared for that). It wasn't a nice as yours though!! Mine had black buckets with a column shift. I was thinking of getting the 10" rear wheels with the 295/50s for mine also but when I went to order the wheels they were no longer available in the SS3s that I wanted.
CutlassS1972
Body work
August 21st, 2014 09:06 PM
olds70supreme
August 1st, 2011 05:22 PM
MIRADAMANia
August 23rd, 2008 07:39 AM
