1968 Cutlass Supreme Wheel Question
Old November 1st, 2017, 09:48 PM
Cutlass217's Avatar
Looking for some advice here...I have a 68 CS with the factory 14s and I am looking to upgrade the wheel and tire size. Of the 3 (15", 16" or 17") what is the biggest size & width (7" or 8") I can put on and do nothing but bolt them on? I don't want to have to modify anything, just give it a different, more "beefy" look.
Cutlass217 is offline
Old November 2nd, 2017, 03:08 AM
rob1960's Avatar
My '68 came with the 14x6 SS2 wheels,way to small in my humble opinion! I went with 15" SS3s, done in the '69 H/O style with the argent painted center with chrome rims from Coker. They are 15x7 front/15x8 rear. I used 235/60s on the front & 275/60s on the rear. I have no issues with rubbing. Unfortunately Coker no longer sells them but I believe they still have the chrome/black SS1s in 15" sizes. My next choice would have been Cragar SS 15s, they look good on anything!!
rob1960 is offline
Old November 2nd, 2017, 06:46 AM
Wheel size is irrelevant. TIRE outside diameter and width is what matters. Offset on the wheels will need to be near zero to allow the widest possible tire to fit.
joe_padavano is online now
Old November 2nd, 2017, 07:01 AM
zeeke's Avatar
I'd assume the 68' is similar to the 71' so if that is the case you have no clearance at the back of the tire but you could get away with an 8" wheel as long as it comes out towards the wheel well. If you are looking to stay stock and cannot find them there is a company in MI that widens stock rims. I looked into it, $30 to ship each way each rim and if memory serves me correctly, which is rare the older I get, it was $120 each rim to widen.
zeeke is offline
Old November 2nd, 2017, 07:43 AM
Cutlass217's Avatar
Thanks!
Old November 2nd, 2017, 07:44 AM
Cutlass217's Avatar
Good to know, thanks.
Old November 2nd, 2017, 07:47 AM
Cutlass217's Avatar
I get the idea on what you’re saying, but I’m not terribly technical and it is sort of Greek to me was well. Ha. So if I wanted to go with a 17” wheel you’re saying it’s more of a tire size issue rather than the actual 17” part?
Old November 2nd, 2017, 07:54 AM
I think the 70-72s have a lot wider rear wheel wells.
Fun71 is online now
Old November 2nd, 2017, 12:40 PM
72 Olds CS
RetroRanger's Avatar
I really like those rims Rob, your 68 looks great !!!
RetroRanger is offline
Old November 2nd, 2017, 08:09 PM
SWinner's Avatar
I have Wheel Vintiques on my 68 CS. They are Olds SS1 reproduction wheels, 15X10 with 5 inch back spacing. Tires are BFG Radial TA's 295/50 R15. Nice and fat but maintains 26.6 inch height.
They look and drive great. 15X8 and 235/60 R15 in the front.
These wheels look like the original Olds SS1's. You have to look closely to determine that they are not the original 14 inch. Your original center caps will fit.
I have no issues with rubbing unless I have 2 back seat passengers and only during a dip or corner.
Steve
https://www.wheelvintiques.com/wheel...obile-ssi.html
File Type: pdf
SWinner is offline
Old November 4th, 2017, 06:59 AM
Cutlass217's Avatar
Looks good, I love that color on your car too!
Old November 4th, 2017, 07:05 AM
Cutlass217's Avatar
Steve
Steve, do you have a couple of photos of you ride you could share? Side shot and a shot showing the tire width from the rear bumper possibly?
Old November 4th, 2017, 09:37 AM
SWinner's Avatar
I've attached them to my original post
SWinner is offline
Old November 4th, 2017, 10:48 AM
Cutlass217's Avatar
Thanks, awesome car!
Old November 5th, 2017, 02:55 AM
rob1960's Avatar
Nice Supreme Steve!! That brings back lots of memories. My first car (mom's hand me down)was the same saffron/black combo like yours except it had the silver lower body color(never cared for that). It wasn't a nice as yours though!! Mine had black buckets with a column shift. I was thinking of getting the 10" rear wheels with the 295/50s for mine also but when I went to order the wheels they were no longer available in the SS3s that I wanted.
rob1960 is offline
T.Wong
May 28th, 2016 12:49 PM
CutlassS1972
Body work
August 21st, 2014 09:06 PM
oldspackrat
May 2nd, 2014 03:17 PM
olds70supreme
August 1st, 2011 05:22 PM
MIRADAMANia
August 23rd, 2008 07:39 AM
Quick Reply: 1968 Cutlass Supreme Wheel Question
