Generator light
Old Nov 11, 2017 | 09:17 PM
cublex's Avatar
Generator light
I have a 74 Cutlass Supreme...last week I had the alternator replace...tonight I noticed the generator light came on when I turn the headlights on and flash when I tun on the signal light...do you thing my battery needs to be replaced?
Old Nov 11, 2017 | 10:34 PM
oldolds88's Avatar
I think something needs a better ground,or the new alternator has a bad diode
Old Nov 12, 2017 | 03:08 AM
You need to check voltage at the battery both with the engine running and off. Running should be around 14-14.5, off 12.7ish.
Old Nov 12, 2017 | 05:34 AM
stellar's Avatar
stellar
Why was the alt changed last week? Is the light coming on and flashing bright or dim? Is the belt tight?
Old Nov 12, 2017 | 06:02 AM
cublex's Avatar
flashing dim
Old Nov 12, 2017 | 06:19 AM
stellar's Avatar
stellar
As mentioned in post #2 check grounds and if they are good check belt tension. If good probably a bad diode bridge or a bad trio. There are a few more possibilities with high resistance in the wiring and the least possible being the battery. The battery may need changed but have it tested. Maybe take the alt back and have it tested or replaced. Still wanting to know why it was replaced in the first place. Was it a used , new or rebuilt alternator you put in? Do you have a volt meter to make some tests?
Old Nov 12, 2017 | 06:45 AM
Was the replacement alternator a parts store rebuilt unit? If so, I suspect it is bad. These rebuilt alternators have a very high initial failure rate. I just went through this with an AutoZone rebuilt I put in my wife's car. The alternator lasted a week before going bad. Output voltage was fluctuating from 9V to 16V.
oldsguybry
Nov 30, 2011 11:48 AM
REDROCKER-S
Oct 5, 2009 05:20 PM
Southern_Hospitality
Sep 30, 2009 02:00 PM
Dkrone
May 1, 2009 08:39 AM
kevin442
Apr 27, 2009 03:07 PM
