Generator light
Generator light
I have a 74 Cutlass Supreme...last week I had the alternator replace...tonight I noticed the generator light came on when I turn the headlights on and flash when I tun on the signal light...do you thing my battery needs to be replaced?
As mentioned in post #2 check grounds and if they are good check belt tension. If good probably a bad diode bridge or a bad trio. There are a few more possibilities with high resistance in the wiring and the least possible being the battery. The battery may need changed but have it tested. Maybe take the alt back and have it tested or replaced. Still wanting to know why it was replaced in the first place. Was it a used , new or rebuilt alternator you put in? Do you have a volt meter to make some tests?
Was the replacement alternator a parts store rebuilt unit? If so, I suspect it is bad. These rebuilt alternators have a very high initial failure rate. I just went through this with an AutoZone rebuilt I put in my wife's car. The alternator lasted a week before going bad. Output voltage was fluctuating from 9V to 16V.
