Generator Light
Old Sep 30, 2009 | 01:04 PM
Southern_Hospitality's Avatar
Generator Light
My generator light is flickering and making noises. My lights were working, but now they are flickering. Any ideas???
Old Sep 30, 2009 | 01:43 PM
Dan Wirth's Avatar
Generator Issue: Test your battery first with a volt meter, make sure it is charged up. If its less than 10.5V, battery may not be holding a charge and you may have to check the cells. If battery is okay, check it when the car is turned on and see what voltage is from the generator. If voltage is about 13.5V -14.5V I would think your battery is getting properly charged and generator is okay. Then start checking the electrical circuit for shorts, opens or loose connections from generator to dash light.
Light Flickering Issue: Your light flickering problem may be a part of a circuit problem if there is a short against it - but I would treat it separately. If you fix your generator issue first, and the light flickering goes away, all the better. If the light flickering doesn't go away, then you'll need to isolate the trouble separately (check the light connector(s) first, make sure they are tight.
Old Sep 30, 2009 | 02:00 PM
Dan Wirth's Avatar
Is your car blowing fuses? (Shorts can be a likely cause).
442Dave
May 1, 2012 04:29 AM
oldsguybry
Nov 30, 2011 11:48 AM
REDROCKER-S
Oct 5, 2009 05:20 PM
Dkrone
May 1, 2009 08:39 AM
kevin442
Apr 27, 2009 03:07 PM
