Light problem 1974 ods cutlass supreme
Old Feb 7, 2021 | 11:04 AM
cublex's Avatar
Hate to keep bothering you all with my issues, when I crank my car up here a few minutes ago...the park light came on even with the switch not on...wnet out about five minutes later...dash lights are on..can't dim the lights by turning the light switch ****...do you think this is a light switch issue?
Old Feb 7, 2021 | 12:23 PM
crimsoncolby's Avatar
That would be the logical place to start. New replacement switches are cheap and easy to replace.
Old Feb 7, 2021 | 01:36 PM
72455's Avatar
1972 U code Supreme
Originally Posted by crimsoncolby
that would be the logical place to start. New replacement switches are cheap and easy to replace.
^^^×2
Old Feb 7, 2021 | 08:40 PM
Schurkey's Avatar
Take the light switch out, LOOK AT IT. The rheostat should be easily visible once removed from the dash.
Park lights issue should be traceable with an ohmmeter.
Old Feb 15, 2021 | 11:28 AM
cublex's Avatar
Light Problem.
I replaced headlight switch still dash light are on when I crank up..I only recall them coming on once you turned the park lights on..also I can't dim the dash lights..I just don't recall them working that way
Old Feb 15, 2021 | 01:32 PM
Did you pull the Instrument light fuse, its the short one in the bottom of the fuse block and try cranking again as what was suggested back in January in your previous thread? That fuse will isolate the dash lighting circuit from the headlight switch. You've worked on a number of things behind your dash over the recent past, double check previous projects wiring.
Old Feb 16, 2021 | 09:24 AM
cublex's Avatar
I got a funny feeling there is orange wire lose that is hot that connects to something that is causing this...I just can't figure out what it is...I taped it off
scott_442
Jun 13, 2012 07:21 AM
Z-Fitch
May 26, 2012 03:48 PM
arod40
Jul 26, 2011 03:45 PM
bryndalfly
Jun 2, 2010 07:36 AM
Oldsmobilliam
Dec 1, 2009 05:56 AM
