Phase out of ethanol fuels
Old Apr 7, 2018 | 07:04 AM
m371961's Avatar
Bills are being proposed to phase out ethanol blended fuels. H.R.5212, S.2519.
Even the conservation groups are realizing the harm of it.
https://www.nwf.org/Home/Latest-News...iofuel-Mandate
Old Apr 7, 2018 | 07:14 AM
jaunty75's Avatar
I think it would be a very good thing, but I'm not holding my breath. The corn lobby is very strong, and much of it is in states that supported Trump in the last election. Trump or his EPA will be hard-pressed to go along with eliminating or reducing the amount of ethanol in gasoline. But, as I said, I couldn't agree more. We have plenty of oil to make gasoline. We should be using corn to feed people.
Old Apr 7, 2018 | 07:29 AM
edzolz's Avatar
Now would be a good time to contact your Reps and Senators to voice your support of these bills. We all know how harmful ethanol is to our cars fuel systems.
Old Apr 7, 2018 | 08:16 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I stopped at a station a couple weeks ago and they had the normal 10% ethanol regular and they had a 15% ethanol that was 15% ethanol and 1 octane point higher (88 octane) and 7 cents a gallon cheaper. I did not buy it but that is not speaking very well for the elimination of ethanol. We can hope.
Old Apr 7, 2018 | 08:25 AM
Wow, this is an amazing display of common sense for Congress.
The whole "oxygenated fuel" push from the mid-70s was an ill-fated attempt to fool carburetors into running more lean than they should during winter months when the choke was closed more frequently. Naturally no one in Congress was smart enough to realize that once EFI became commonplace, the minimal emissions benefit of that went away. Of course, the ag lobby pushed to keep this gravy train in place and even expand it.
I'm all for domestically produced renewable energy sources, but nothing good comes from E10 or E15. Now, if E85 were commonly available, we could all retune our cars to take advantage of the improved performance.
Old Apr 7, 2018 | 08:56 AM
35tac's Avatar
Joe, on what cars could we use E85?
Old Apr 7, 2018 | 09:05 AM
m371961's Avatar
I have argued that ethanol blends are actually more harmful to the environment for years with the save our planet people. Finally the Sierra club people are admitting it.
Old Apr 7, 2018 | 09:13 AM
Unless you have a newer vehicle designed for FlexFuel, you must modify the car to use (and take advantage of) E85. Since ethanol has higher octane rating, you can run higher compression and more timing. You need to ensure that all parts of the fuel system are ethanol compatible. The biggest change is the fuel metering in the carb. Stoichiometric A/F for gasoline is 14.7:1. for E85 it's 9.8:1. This isn't just a jet change - you typically need a carb with larger passageways in the fuel circuits. You can buy E85 carbs today.
Old Apr 7, 2018 | 09:36 AM
VC455's Avatar
Barely Registered
Originally Posted by edzolz
...We all know how harmful ethanol is to our cars fuel systems.
True.
And there are other aspects that don't get much attention. Ethanol has one-third less energy per gallon. If you use ethanol-free gasoline versus a 90% mix, you gain about 3% horsepower and 3% fuel economy.
I know some of you are already making but-faces. So, read on...
Yes, E85 engines make more power than gas engines.
  • as Joe said, E85s higher octane rating allows purpose-built engines to have higher compression ratio to gain efficiency
  • ethanol cools the intake charge more than gasoline, which means more mass of air and fuel for each stroke
  • cooler intake charge also allows higher boost pressure on supercharged and turbocharged engines
Viola! More power from ethanol.
Old Apr 7, 2018 | 09:46 AM
Originally Posted by VC455
True.
As I noted above, if you have EFI or even a CCC 307 with an O2 sensor, the ECU automatically compensates for the A/F difference of E10 and there is no HP difference. If you rejet your carb, same thing. Yes, you still have the mileage loss, but what matters is the cost per mile. If E10 cost per gallon is lower than for straight gasoline, the mileage difference is irrelevant.
Old Apr 7, 2018 | 10:28 AM
Phoenix is an area that is mandated to use oxygenated fuel, and I don't see the federal EPA, state AZDEQ, or any other gub'mint entity changing that any time soon (as in not in my lifetime) - way too many regulations and studies would be needed. Heck, it took a LOT of time and work just to get rid of emissions testing for older cars. The law used to be anything built in 1967 or later had to be emission tested annually; now if your 1967 or newer car has classic insurance it doesn't have to be tested.
The E-10 we have now is a lot better than the MTBE poison that was used previously.
Old Apr 7, 2018 | 10:48 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
My boss who runs our fuel department claims there needs to be a 18 cents per liter difference in price or 72 cents a gallon difference to not buy the non ethanol 91 premium gas, we have a 10 to 14 cents per liter difference vs 10% ethanol 87 regular fuel. Of course most his data is on modern cars, their ECM's are probably advancing the timing, allowing a better burn.
Old Apr 7, 2018 | 11:35 AM
VC455's Avatar
Barely Registered
...the ECU automatically compensates for the A/F difference of E10 and there is no HP difference.
Conflating proper stoichiometry with equal HP output leads to the conclusion that the engine can make the same power regardless of the energy content of the fuel.
Old Apr 7, 2018 | 04:13 PM
Sampson's Avatar
Holy crap! What is the world coming to? Next they will try to introduce bills for vented gas cans that actually pour gas! Someone stop the madness
Old Apr 7, 2018 | 04:31 PM
m371961's Avatar
That gas can regulation has to go, what a pain.
Old Apr 7, 2018 | 05:08 PM
When I buy gas cans, I buy plastic ones, and a "water can repair kit" that has a old fashioned nozzle, cap, and vent button. Swap caps, drill hole, push in button, new "old style" can. I'm such a rebel, but I have no excuse, my name is Lee.
Old Apr 7, 2018 | 06:03 PM
cherokeepeople's Avatar
oh those new gas cans suck. i live in iowa and i deal first hand with the ethanol industry.don't get me started at just how much i hate them.
Old Apr 7, 2018 | 06:30 PM
Sampson's Avatar
I have to wonder how much gas is spilled with the non vented versions vs how much would be vented into atmosphere through a negligently left open vent cap?
I also wonder if anyone in congress has to pour his own gas?
Old Apr 8, 2018 | 03:19 AM
35tac's Avatar
Thanks for the information.
Wayne
Old Apr 8, 2018 | 04:18 PM
83hurstguy's Avatar
This is a good read, various fuels dyno tested in a SCCA-racer Miata... includes 93 E10 vs 93 E0.
https://grassrootsmotorsports.com/articles/fuel-truth/
Old Apr 9, 2018 | 05:48 AM
Luke, that's a cool link. Thanks for sharing.
It's interesting to see the difference in HP and torque rurnning different fuels. I wonder how much of a difference there would be in emissions (HC, CO, NoX, etc.)?
FWIW, I run E10 in my dailly drivers all the time. The price difference is so great and I don't gain that much extra mileage. Luckily, I can still get 100% gasoline for my Olds.
Old Apr 9, 2018 | 08:30 AM
Bfg's Avatar
Bfg
The Name "Lee" should be ban cause it's very offensive to some!
Old Apr 9, 2018 | 09:23 AM
Tell you what, I'll change my name in trade for getting rid of everything I find offensive in this country.
Old Apr 9, 2018 | 09:34 AM
redoldsman's Avatar
Where the hell did this come from? You can't be serious.
Old Apr 9, 2018 | 01:28 PM
jaunty75's Avatar
This was all over the news last summer when we were busy pulling down statues of historic figures all over the country.
Here's the story.
https://www.nytimes.com/2017/08/23/b...ttesville.html
Our poor country surely has gone off the deep end.
Old Apr 9, 2018 | 01:53 PM
dennis_30281's Avatar
Henry Ford's Model T carburetor could be tuned to run on gasoline or alcohol because in "the good ole days" the farmers took some of their corn and made fuel out of it. That's before gasoline was so widely distributed and all the farm equipment ran on alcohol.
Dennis
Old Apr 9, 2018 | 01:59 PM
This thread has gone off the deep end. What the heck does this have to do with the topic of ethanol?
Old Apr 9, 2018 | 02:15 PM
m371961's Avatar
Old Apr 9, 2018 | 05:57 PM
Back when my car had to be emissions tested, I had a conversation with Bob Powers on "tuning for emissions". One of his recommendations was to mix alcohol with gas to bring the alcohol content to ~20-25% and that decreased my car's tailpipe HC and CO readings VERY dramatically, as you can see below. My car didn't get tested for NOx so I can't comment on that.
Old Apr 10, 2018 | 05:24 AM
Kenneth those are drastically different numbers!
Was this your Cutlass that achieved those numbers? If so, I would like to know the difference for a modern car.
BTW Dennis, you are correct. I've heard too that Model Ts and other early cars were designed to run on ethanol.
Old Apr 10, 2018 | 07:36 AM
  #31
edzolz's Avatar
My first car was a 1929 Model A. We lived out in the country and there was a natural gas well on my dads property. For those who don't know, on a cold night a gas well will condense liquid gasoline called "drip gas". It is actually a very high octane fuel without any lead or other additives. It is illegal to run it in cars because taxes are not paid to the county or state for road use. My model a would run exceptionally well on drip gas. Just had to mix it about 50/50 with low octane regular.
Old Apr 10, 2018 | 07:45 AM
  #32
OldsAl's Avatar
I’m from Vancouver, Canada and while we do have ethanol blended fuel we have 94 premium through Chevron that has no ethanol whatsoever. Been running this gas in all my high compression motors for as long as I can remember. In fact we also have 93 no ethanol gas from Petro Can. I stick with the Chevron.
Old Apr 10, 2018 | 09:11 AM
  #33
Yes, those are the readings for my '71 Cutlass. I don't have access to any info for a modern vehicle, but I suspect the difference wouldn't be as drastic for an engine with EFI, computer controls, and catalytic converter.
Old Apr 13, 2018 | 11:22 PM
  #34
72GoldOlds350's Avatar
I'm in Washington State - and I'm super jealous.
cdrod
Jul 4, 2016 07:48 PM
1966 442
Mar 4, 2013 07:19 PM
Bluemeanie
Feb 2, 2013 10:02 PM
1966 442
Nov 15, 2012 07:55 PM
Grumpy
Mar 30, 2009 04:25 PM
