DIN Hack Repair Opinions
Old Apr 16, 2018 | 08:53 PM
Troys Toy 70's Avatar
Once Olds Always Olds
Ok a little fun and excitement for everyone. I am going to upload a set of pictures for 3 lower dash pieces. Each has been hacked on for an aftermarket radio. I have a plan, but want to see if you all agree. Also, one of the pieces has a factory mistake let’s see. The first to spot that too. Are you ready?
Option 1) This unit has the least amount of hacking around the radio, but has three of the mounting tabs broken.
Old Apr 16, 2018 | 09:03 PM
Option 2
Here we have a wonderful specimen as far as no rust, but alast someone really went to town on the radio. The unfortunate part is that I cannot keep it with the dash pad it came with. The dash pad is great and I am using the pad for the 442,
Old Apr 16, 2018 | 09:08 PM
Option 3
This is the original dash unit out of the 442. Unfortunately someone took a paring knife to it and busted out the corners by the volume ****.
Old Apr 16, 2018 | 09:12 PM
My thought is to use the 442, and fix the corners. I will have a factory radio in the hole, and I believe the new burl wood piece will cover the majority of my repair. I am thinking I will disassemble option two and use the grounding strips off of it.
What do you all think?
Also, did you find the factory mistake?
Old Apr 17, 2018 | 06:52 AM
jharsh's Avatar
Sounds like a good plan. Option 2 appears to be missing what I assume is a Capacitor bracket.
Old Apr 17, 2018 | 03:16 PM
I will give you partial credit. Option 2 is the one with the defect.
I think the bracket you are referencing is the courtesy light bracket for the ashtray. Option 2 did not have courtesy lights, but the other two did. If that was the bracket you were referencing, then no that was not the defect.
Old May 10, 2018 | 06:53 PM
Option 2 has the factory defect as mentioned before has the factory defect. The metal ash deflector that goes over the top of the ash tray is completely outside the ash tray. The part that is pop rivited to the backside of the top of the ashtray should have been on the inside.
Old May 10, 2018 | 07:01 PM
Now for the fix
So the first thing is to understand that the radio is not centered in the dash. It is closer to the top. This was going to present a problem as I was going to use the right side to make the left side repair. You can see it as I flipped the wood trim over.
Old May 10, 2018 | 07:20 PM
Cleaned up the existing hack job to get what need to be done. Made a template. Also say hello to my little friend.
Old May 10, 2018 | 07:26 PM
Cut the donar piece
Old May 10, 2018 | 07:31 PM
Primary trimming is done now for the tedious part. A good place to stop for tonight.
Old Jun 9, 2018 | 10:51 AM
Final trimming done and it is now glued in place. I still have a little bit of finishing to do, but I am not going to get too crazy as the wood grain and ***** cover the majority of the repair. One item to note, the opening is very close to 4” on the nose. I initially measured the opening at 4 1/16”. I kept it just shy of 4” 1/16, but this was still way to big, this made my replacement piece too narrow, which I filled with a mixture of glue and shavings. I think it turned out pretty good.
Old Jun 10, 2018 | 06:38 AM
RetroRanger's Avatar
72 Olds CS
Came out good.
Once the wood grain is in place no one should be able to tell it was repaired
Old Jun 10, 2018 | 05:27 PM
Thanks, I did not think it was a bad first attempt. Just a little more finish work and paint it, and wood grain and I do not think anyone will be able to see it.
Old Jul 8, 2018 | 01:56 PM
When it came time to re dye the dash, I used SEM Satin Black
Old Jul 8, 2018 | 02:14 PM
And here are the results
Old Jul 8, 2018 | 02:21 PM
Today added some chrome detail with Molotow’s liquid chrome.
Old Jul 10, 2018 | 04:30 PM
Hoffman2099's Avatar
Wow, that satin black looks great!! I used landau black on my dash and I think it looks to shiny.
Old Jul 10, 2018 | 06:23 PM
Thanks! I would like to claim that after extensive research and trial and error I found the color. However, a fellow Olds enthusiasts turned me on to it. So, he gets the credit for all the research as it really looks nice. It looks better in person than the pics.
Now to order the wood trim.
Old Jul 10, 2018 | 10:39 PM
4speed455's Avatar
I used H&H Classic for my dual gate shifter and console wood grain, much nicer then what came on the top plate from The Parts Place. https://classicoldsmobile.com/forums...woodgrain.html
http://www.hhclassicauto.com/mission.html
I used the SEM Landau Black on my dash and I am very happy with the color and sheen. It is very close to original.
https://classicoldsmobile.com/forums...dash-trim.html
Old Jul 13, 2018 | 07:13 PM
I will definitely be using H&H for the wood trim. What do you use for an adhesive for the Woodgrain? Or does it come with it?
Old Jul 13, 2018 | 09:58 PM
4speed455's Avatar
3m trim adhesive is what H&H recommended. It dries clear.
https://www.amazon.com/gp/aw/d/B0002MID28/ref=mp_s_a_1_1?ie=UTF8&qid=1527539402&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=3m+plastic+and+emblem+adhesive&dpPl=1&dpID=41BQXdVJUBL&ref=plSrch https://www.amazon.com/gp/aw/d/B0002MID28/ref=mp_s_a_1_1?ie=UTF8&qid=1527539402&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=3m+plastic+and+emblem+adhesive&dpPl=1&dpID=41BQXdVJUBL&ref=plSrch
Old Jul 16, 2018 | 07:06 AM
oddball's Avatar
H&H's do not have an adhesive on them.
I strongly recommend a spray contact adhesive. Just mask up the dash real well (including holes from the back side...........) and spray on the dash and the back side of the trim.
I had problems with liquid glue squeezing out in places and it's a real pain to get into the smaller areas like around the A/C controls and radio. Left without adhesive those narrow bits will rattle.
Brians1
Mar 12, 2019 05:29 PM
sjay1989
Mar 2, 2019 03:38 PM
OldsAl
Feb 21, 2019 05:45 AM
72455
Dec 25, 2018 01:22 PM
OldsAl
Jan 21, 2018 03:21 PM
