83 cutlass brougham
Old April 17th, 2018, 09:06 AM
Naranjo13's Avatar
83 cutlass brougham
I have an 83 cutlass brougham Edition. Car has been running fine until yesterday it stalled on me and wouldn’t stay on idles for a couple seconds fine and cuts off. Could it be a carburetor issue ?
Naranjo13 is offline
Old April 17th, 2018, 09:38 AM
Olds Fever
CRUZN 66's Avatar
Welcome to the group... Your issue could be several things... Could start by checking for any vacuum leaks... If no vacuum leaks, check for fuel flow/pressure to the carburetor... If you have no vacuum leaks and fuel pressure is good, you most likely have a carb issue...
CRUZN 66 is offline
Old April 17th, 2018, 04:24 PM
Naranjo13's Avatar
I adjusted a few screws according to the Haynes manual. Now the car stays on and isles fine but soon as I give it gas it shuts off... I’m not to car savy as this is my first car that I’m making it a project car to learn on. How would I check for a vacuum leak ?
Old April 17th, 2018, 04:26 PM
Naranjo13's Avatar
[QUOTE=Naranjo13;1090096]
I adjusted a few screws according to the Haynes manual. Now the car stays on and isles fine but soon as I give it gas it shuts off... I’m not to car savy as this is my first car that I’m making it a project car to learn on. How would I check for a vacuum leak /QUOTE] I just don’t understand why it would idle fine now and soon as I give it a little gas while in drive cuts off ??
Old April 18th, 2018, 10:54 AM
Lance
ROCKET VAPOR's Avatar
[QUOTE=Naranjo13;1090098]
I would check for a dirty fuel filter causing a fuel flow restriction.
ROCKET VAPOR is offline
Wildcard
November 29th, 2012 08:52 PM
69Rman
March 16th, 2009 05:40 PM
POKANOKET
July 14th, 2007 02:58 PM
Tod
September 22nd, 2006 07:45 AM
<RonC>
June 22nd, 2004 12:36 PM
Quick Reply: 83 cutlass brougham
