build update
Old Apr 9, 2018 | 11:13 PM
Kyron219's Avatar
build update
Heys guys just wanted to updated you guys oon my buid.. starter 69 olds 350 #5 heads.. The block and heads have both been blasted, baked, and mangafluxed everything is good there...Now what i am going with. Speedpro flattop pistons, origanal crank which is alos getting machined, mondello cam tappets, valve springs, and intake and exhuast valves also a mondello timing chain..edlebrook intake pro rpm with ah edlebrook 750 cfm carb (i am thinking on switching the carb to a 650 or 700 cfm).. so thats the update engine wise as far as trans ill mostly keep the 200 r4...
Old Apr 10, 2018 | 07:04 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Be careful how you are buying those Mondello parts from. I hope they are not from Lynn.
Old Apr 11, 2018 | 09:03 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The pistons Cutlassefi sells are much better, see if he has a set left. Don't buy squat from Mondello, unless it is Benard Mondello.
Old Apr 19, 2018 | 12:27 PM
Kyron219's Avatar
She's almost there
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
ATrain1
Non-Olds Engines
Aug 9, 2012 08:02 AM
1973olds98
Apr 30, 2010 01:22 PM
69 442 protour
Dec 9, 2006 09:25 PM
