71 Cutlass 350 AC brackets
ok, i figured out which bracket was right, it is marked 391366 D2. the other one appears to be for a 66 Toronado.
the bracket attaches at 2 points on the engine: a head bolt and a blind hole in the intake manifold. I have no hardware to attach it, so need to figure out what nut size fits the head bolt stud and what bolt goes in the hole in the intake. it appears to be fine thread.
the threads are also in poor shape in the intake and head bolt, so that makes it a little harder.
in case anybody cares, the threaded hole in the intake for the AC bracket appears to be 3/8"x24. a tap that size went in without much resistance. threads were pretty bad, i guess bolt wasn't in there for a long time.
also, the nut that threads on the head bolt stud is 7/16"x20.
i figured this out by just buying some nuts/bolts at home depot and seeing what worked. not well versed with standard size fasteners.
I'll agree it's not the most elegant bracket, but it works ands that's what you need first, you can work on looks on rev2
I made a couple brackets on my engine too, one is like yours in that it's obvious it's a part not from the factory, the second one tho I welded and ground to look like stamped piece and IMO it came out great.
brandon reynolds
Jan 12, 2019 05:48 AM
Oldssupreme
Apr 14, 2018 06:56 AM
olddaz
Aug 27, 2014 06:39 PM
