9 inch or 11 inch booster? does it really matter?
Old Apr 17, 2018 | 09:31 AM
Toocool's Avatar
I ordered a Right Stuff disc brake conversion kit (front only) for my Vista Cruiser. I got it today and it has a 9 inch booster, I was expecting an 11 inch. My fault, I didn't double check it when I ordered it. Will it matter with a totally stock 330 engine? I would think it would make enough vacuum. Any opinions?
Old Apr 17, 2018 | 11:37 AM
Single or double diaphragm 9"?
Old Apr 17, 2018 | 12:53 PM
Toocool's Avatar
Single as far as I know. Another option is to just use the 11" booster that is on the car with the drum brakes.
Old Apr 17, 2018 | 01:27 PM
I'd go with the 11", but check the actuator of the booster to master cylinder to make sure they are compatible.
Old Apr 17, 2018 | 01:54 PM
11971four4two's Avatar
MOTORHEAD
No
Get the right stuff on the phone
buy a few more things
No mix drum / disc old / repro parts brake system
Old Apr 17, 2018 | 04:35 PM
VC455's Avatar
Barely Registered
A single 9" will give you a third less power assist versus the 11".
You will definitely notice that difference.
Old Apr 17, 2018 | 04:37 PM
Note that the 64-66 cars came with a 9" booster from the factory. GM went to the stronger 11" booster when disc brakes became available in 1967.
4SPEED67
Oct 5, 2017 08:08 PM
rustycragars
Dec 25, 2016 06:06 PM
top down
Mar 12, 2016 08:57 AM
c-towndave
Brakes/Hydraulic Systems
May 16, 2014 05:05 PM
HIGHCOMP425
Aug 5, 2010 02:35 PM
