Courtesy dome light
Old May 1, 2018 | 03:54 AM
Dadsbadass442's Avatar
Courtesy dome light
How do I test this with a multi-meter. Scenario: Car is on, headlights on, doors open and this does bulb does not come on with old or new bulb. Want to test and see if this thing is even wired. How do I do that with a multi-meter?
Old May 1, 2018 | 04:40 AM
Take the lamp out, you should have 12v on one side measured with a volt meter and ground on the other with door open measured with an ohm meter. Door closed 12v on one side nothing on the other. The light works with 12v on it at all times, the door/s jamb switches and headlight switch provides the ground to turn the lights on and off. Does the headlight switch turn on the courtesy lights when rotated all the way ccw?
Old May 1, 2018 | 04:55 AM
cherokeepeople's Avatar
does the one on the drivers side work?
Old May 1, 2018 | 05:08 AM
Good point, I forgot to ask this.
Old May 1, 2018 | 05:20 AM
Also, you want to check voltage with a voltmeter, not an ohm meter. Since most everything is a multimeter today, it's the same instrument, just set to 12 VDC, as opposed to 1K Ohm.
Old May 1, 2018 | 05:35 AM
My442's Avatar
Check the switches in the door jams.
They get corrosion on them, and don't work.
P.S. Try the simple things first - 12 volts and then a new bulb.
jorosal
Dec 9, 2017 07:20 AM
53oldsmobile
Jul 12, 2017 05:58 PM
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
gerlof_1
Jan 24, 2008 12:19 AM
HAFROD
Jan 22, 2008 05:12 AM
