77 GMC Jimmy brake problem
Old Sep 25, 2017 | 06:12 AM
Lars's Avatar
Well i have a rock crawler now that takes all my money and time, with a brake issue. I put "tons" under it (D-60 front and a corpret 14 bolt disc rear).
The 14 bolt has duel pistons brake calipers so i put an 82 corvette master cylinder in it thinking it would compensate for the rear disc. Ive bled it and all the parts are in good working order, but i still have a squishy pedal.
When i clamp the rear brake lines the pedal feels great, the only thing i haven't swapped is the combination/ prop valve. Some say i should gut mine, some say i should get a disc/ disc prop valve, what say you?
And is there enough displacement in my master to push a 6 piston brake system?
Old Sep 25, 2017 | 08:50 AM
rustyroger's Avatar
'87 Delta 88 Royale
Is the Corvette mater cylinder compatible with the rear calipers?. If not you will need one that is.
If you have all the air out of the system then the pedal travel comes from pushing out the pistons in the rear calipers.
On the face of it master cylinder with a larger bore supplying the rear is what you need, the exact size I don't know.
Roger.
Old Sep 25, 2017 | 09:47 AM
toymobile's Avatar
Rear bleeder valve pointed UP I hope??
Old Sep 25, 2017 | 05:47 PM
Lars's Avatar
yes they are
CyberCholo
Oct 17, 2016 12:28 PM
Jimmy Jo
May 30, 2014 05:42 AM
Jimmy Jo
May 24, 2014 02:09 PM
Jimmy d mcphail
May 7, 2013 07:16 AM
Jimmy d mcphail
May 3, 2013 06:02 PM
