442 engine start in 26 years
You can follow my thread. My 1972 Cutlass Supreme has been sitting for 35 years.
https://classicoldsmobile.com/forums...s-supreme.html
First I would remove the spark plugs and squirt ATF or PBBlaster in each of the cylinders. Then reinstall the plugs (to keep dirt and varmits out) and leave it sit for a few days. Then remove the plugs and use a ratchet/socket on the crankshaft pulley bolt and rotate the engine to make sure it is not seized.
mryoung4815
August 19th, 2011 11:51 AM
