lift loop in action
Old Oct 29, 2016 | 08:17 PM
442Fred's Avatar
lift loop in action
I thought I would post a picture of the lift loop being used as intended. I am sure many of you have wondered why it is called a lift loop? Very simple to grab the motor and lift, no need to bolt anything to it of course once the lift loop is in place.
This is a 455 with an M21 attached to it and it has perfect balance on the rear lift point.
Old Oct 29, 2016 | 08:33 PM
don71's Avatar
same but different
Yea, just like the factory did it.
Old Oct 30, 2016 | 03:56 AM
Hey! Where'd you get that?
Old Oct 30, 2016 | 05:14 AM
442Fred's Avatar
It came from a guy who was sponsored by Oldsmobile in the 60's and 70's he told me it was on one of engines that they sent him. It is the only one I have ever seen outside of a few pictures.
Old Oct 30, 2016 | 05:20 AM
Makes sense. I was gonna say, those are factory-only, as far as I ever knew.
Cool!
Old Oct 30, 2016 | 05:43 AM
68442's Avatar
Is it Hollow tube(Pipe) or solid bar stock?
Old Oct 30, 2016 | 06:28 AM
Chris Witt had one and posted photos here.
Old Oct 30, 2016 | 11:32 AM
Be careful doing that. I make those things for a living (amongst other factory equipment) and there's a reason new ones don't look like that. Assuming that 50 year old steel straps, bolts, and bar stock is still at original strength is also a dicey thing.
It would suck to drop an engine, and it would REALLY suck to be underneath it when it happened.
If you must do that, a good trick is to lift just a little bit, and let it hang for a while and see if anything is starting to stretch or deform; this way, if it is going to let go, the engine will just drop a bit and no harm will be done. We load test our end effectors to at least 125% of intended load and measure deflection before and after a 15 minute hang at 125%.
Mike77
Jan 24, 2014 12:00 PM
1971viking
Drivetrain/Differentials
Jul 19, 2013 12:40 PM
salon74
Jun 16, 2013 09:07 AM
jims2000lt
May 11, 2013 06:18 AM
jensenracing77
May 1, 2009 02:35 PM
