1961 oldsmobile starfire dual master cylinder conversion
Old Nov 7, 2016 | 06:16 AM
deleted comment - tried copy a thread from another post.
Old Dec 30, 2016 | 08:48 AM
Sleepybeaver's Avatar
Hello everyone so I have had 2 other post regarding this conversion
My new question is has anyone used or have info on using a 1962 cadillac dual bendix master cylinder with the 4 bolt to vacuum booster
For this conversion
Old Dec 30, 2016 | 12:59 PM
Oldsfan's Avatar
I have often wondered about that, too. I wonder if the single master cylinder for a '61 Cadillac is the same part number as for a '61 Olds. That would be a pretty good indicator that you could swap the '62 cylinders.
Old Dec 30, 2016 | 02:37 PM
Rund to Rund suggested this from your other thread.
If two of the bolts/studs are in the right positions, just use them. Also make sure the pushrod length is correct for the new plunger and the distance it must travel. You can use a longer pushrod with a bolt pattern adapter (make it yourself) if needed.
Maybe this from the Cadi site will help:
http://forums.cadillaclasalleclub.or...topic=125646.0[/QUOTE]
KQQLCAT
Brakes/Hydraulic Systems
Nov 7, 2016 04:45 PM
Sleepybeaver
Nov 7, 2016 12:29 PM
Jakespeed63
Aug 25, 2015 12:20 PM
twintracks
Mar 15, 2014 11:09 AM
