1961 starfire dual master cylinder conversion
Old November 6th, 2016, 05:03 PM
Sleepybeaver's Avatar
Hello everyone I am hoping you guys can help me with doing a dual master cylinder conversion on my 61 Starfire, currently I have the single master cylinder that I would like to change to a dual master cylinder but yet keep my drum brakes, (I am not doing a disc brake conversion at this time and may not do it at all unless I have to)
Please any and help is appreciated
I have looked through the threads concerning this but it seems everyone is doing disc brake conversion
Sleepybeaver is offline
Old November 7th, 2016, 02:59 AM
chopolds's Avatar
It's the same procedure, all you do differently is use a drum-drum master cylinder. Even a power brake set-up is very similar, again, you must use a PB master cyl. You can get them in drum-drum- and drum-disc.
chopolds is offline
Old November 7th, 2016, 03:42 AM
Ty for the reply
The problem I'm having is that my single master cylinder has four bolt holes that attaches to the vacuum booster and I cannot seem to find a dual master cylinder with that setup
Old November 7th, 2016, 06:16 AM
Run to Rund's Avatar
If two of the bolts/studs are in the right positions, just use them. Also make sure the pushrod length is correct for the new plunger and the distance it must travel. You can use a longer pushrod with a bolt pattern adapter (make it yourself) if needed.
Run to Rund is offline
Old November 7th, 2016, 12:29 PM
chopolds's Avatar
I just used a commonly available booster and master. IIRC, I just had to oblong a couple of the original mounting holes.
chopolds is offline
young olds
November 21st, 2022 03:09 PM
KQQLCAT
Brakes/Hydraulic Systems
November 7th, 2016 04:45 PM
Jakespeed63
August 25th, 2015 12:20 PM
twintracks
March 15th, 2014 11:09 AM
Quick Reply: 1961 starfire dual master cylinder conversion
