Big Block vs Small Block
Hi everyone,
I am new to this forum so please forgive me if I am asking a question that has been answered 100 time before.
I have a '68 442 convertible with the 400cid engine , 325hp (automatic car). Would my engine be considered a big block or small block? The engine is bronze with the orange air cleaner.
Thanks all!
Phil
Thanks all!
Phil
Olds has an incredibly easy way to identify engines and big vs small block. The heads have a cast numeral/letter to the lower left of the valve cover, and the block has a casting number of some seven or so digits followed by a large numeral/letter.
If it has letters, it's a Big Block Olds. If it has numbers, it's a Small Block Olds.
Your car, being a 68 442, will have C heads and G Block, meaning the third in the series of heads (after A and B) and a G block 400. You will have the big valve C heads with your 442 engine (since it's a performance car) and your G block, while noted above won't rev quite as high, but will have good ***** on the street.
Fyi
Welcome. Yes, this has been discussed hundreds of times.
First, there is no "official" definition of big block or small block. In Chevyland, the SBC and BBC are completely different engine families with few interchangeable parts (though I must take this opportunity to ridicule Bruce Springsteen who sings about his "69 Chevy with a 396, fuelie heads, and a Hurst on the floor..."
The 1964-1990 Olds motors are actually all of a common architecture - common bore spacing, common crank-to-cam centerline, common motor mounts, common front cover and accessories, etc, etc. This is why BBO and SBO take the same cams and valvetrain, and why people who build DX blocks often use 425 cranks. The only fundamental external difference between the BBO and SBO is the deck height. SBO is 9.33", BBO is 10.63". We in Olds-land have arbitrarily defined the short deck motors to be "small blocks" and the tall deck to be "big blocks", but the reality is that the relationship is more like that of the Chrysler B-block (383) and RB-block (440) motors.
As for the first-gen Olds V8s, there are really THREE different deck heights over the years.
).The 1964-1990 Olds motors are actually all of a common architecture - common bore spacing, common crank-to-cam centerline, common motor mounts, common front cover and accessories, etc, etc. This is why BBO and SBO take the same cams and valvetrain, and why people who build DX blocks often use 425 cranks. The only fundamental external difference between the BBO and SBO is the deck height. SBO is 9.33", BBO is 10.63". We in Olds-land have arbitrarily defined the short deck motors to be "small blocks" and the tall deck to be "big blocks", but the reality is that the relationship is more like that of the Chrysler B-block (383) and RB-block (440) motors.
It's not really a suggestion, more of how it was done. Obviously, it won't work on modified engines, or LS transplants, or Fords....
limitations
Agreed. But your suggested discerning filter doesn't work on later engines either like that 403s & 307s where the small block heads all have a number followed by a letter.
Stop nitpicking about it.
Is there a reason you are climbing up my posterior today?
final thought
You flatter yourself by thinking that I am invading your posterior. I was completing your post so that the information was complete & accurate. Thanks for playing.
Mr. Padavano, are you saying our terms big block and small block for Oldsmobiles is not a construct from the factory or Oldsmobile itself? But a construct from us enthusiasts to discern the tall and short deck blocks which Oldsmobile would have been considered all the same block by Oldsmobile, as in your example Chrysler considered both the tall and short deck big blocks as one block with a different deck height?
... are you saying our terms big block and small block for Oldsmobiles is not a construct from the factory or Oldsmobile itself? But a construct from us enthusiasts to discern the tall and short deck blocks which Oldsmobile would have been considered all the same block by Oldsmobile, as in your example Chrysler considered both the tall and short deck big blocks as one block with a different deck height?
But then I don't recall ever seeing either of these terms in any Chevrolet publication either. I believe it was "V8" and "Mark IV V8."
Meaning: ANYWHERE. The factories did not invent this term. It was created by enthusiasts and has no fixed definition. We really need to get over it.
Wasn't picking a fight, just actually interested. I wasn't sure what the real source of the terms was. Interesting though...
I know Pontiacs are all midblocks, as there is no big and small block... but funny enough, by the Oldsmobile standard of deck height, the 301 would be a short deck therefore a small block.
For example, what do you call a Chevy W-motor? Is a Ford Y-block "small" or "big"? What about the FE, 385, and MEL families?
After the iconic flathead, I seem to recall the Y-Block, the FE [Ford/Edsel] Block, the Windsor Block, the Cleveland Block, and the Lima Block.
I guess each one was a Better Idea than the last...
As a total digression, I'm not a F_rd guy, but didn't F_rd make something like five different OHV "blocks" in the '50s - '70s time frame?
Y-block (272/292/312)
MEL (Mercury/Edsel/Lincoln)
FE (332/352/390/391/406/427/428)
Windsor/Cleveland/Modified (221/260/289/302/351/400M)
385 family (429/460)
The factory tall-deck Chevy motors were medium and heavy duty truck blocks. I ASSUME this was done to allow the use of pistons with thicker domes and thus more durability in truck applications (along with lower compression). Don't confuse aftermarket tall deck blocks (designed to accept a longer stroke) with the factory truck blocks. The passenger car and light truck BBCs all used the same deck height.
Chevy is not unique in doing this, either.
Hi everyone,
Thanks all!
Phil
Thanks all!
Phil
400-455 big
350 small
