FiTech install #3 today
Old Nov 3, 2016 | 05:00 PM
1970-W30's Avatar
Started at 10AM by 3:30 the 72 was running with it's new FiTech system. Since the O2 sensor bung was already in place as was a vent return line, the job was a breeze. Especially since I had two installs under the belt already. The very nice 72 convert belongs to a friend of mine and is running a bone stock 350 with 2.78 gears. Idle was much smoother and on its initial test drive we hadn't gone more then a block, the owner noticed much better throttle response. I noticed some changes, the gauges on the command center are now glycerin filled and the fuel hose for the AN style fittings goes on the barbed fittings a lot easier.
Old Nov 4, 2016 | 05:27 AM
You don't work for FiTech, do you?
Really, from what has been said on our board and others I browse it seems like FiTech is where it's at! I would consider buying one if I were to put fuel injection on my Olds.
Old Nov 4, 2016 | 08:26 AM
1970-W30's Avatar
You know, I should be getting a kickback from them for each unit I install, probably will be doing another one shortly..... Either that or become a dealer for FiTech........
Old Nov 4, 2016 | 08:29 AM
The least they should do is send a rep to do a video of your installs. It would make you famous on YouTube and the rep could provide you with free beer!
Old Apr 14, 2017 | 03:12 PM
ART T's Avatar
Have you had any problems with fuel leaks? I had a pipe plug leaking on the right side cover. It is on the bottom of the return passage.
Old Apr 14, 2017 | 04:12 PM
1970-W30's Avatar
Nope, no leaks on any of the installs, though I don't have my 65 anymore, would have been a fool to turn down the money that it brought. New owner really liked the fuel injection.
Bought another car already, not an Olds, but something very similar to what I had back 68 or so, taking a bit of flak from my Olds buddies but I had expected that....
1970-W30
Jul 17, 2017 07:06 PM
distributorguy
Oct 28, 2016 09:44 AM
richkidd24
Jun 3, 2016 02:53 PM
J-(Chicago)
Apr 9, 2008 04:28 AM
mumpspro
Sep 24, 2006 11:03 AM
